-   -   solid or foamcore hull ? (https://www.offshoreonly.com/forums/cigarette/158818-solid-foamcore-hull.html)
stevesxm 05-21-2007 04:32 PM
hi,
have 96 top gun... looking to install new depth sounder. instrument guys keep asking me if hull is solid glass or foam core.... assuming this boat is stock and not kevlar or carbon, would this hull be solid or cored ?
stevesxm 05-23-2007 06:23 AM
common... are you kidding ?
REALLY ???? no one here has ever drilled into or seen the bottom of the engine bay compartment on a top gun apart ? no one knows if its solid or foam core ?
CIG3 05-23-2007 08:02 AM
Cored...
stevesxm 05-23-2007 02:33 PM
thx
c_deezy 05-24-2007 08:40 AM
Most newer boats have a spot for a depth sounder somewhere in the bilge where there isn't any coring for a shoot-thru transducer. Should be a small circular section about two inches or so in diameter, give or take.
chewy1955 05-25-2007 12:37 PM
Can someone expain this a little more... "Solid or Foam Core" ?What is the "Foam Core" made of? How Thick? How does it effect the dxepth sounder? Where is the spot on the hull of a TG for the depth sounder? I have a 98 and there is a transducer barried into the hull just in front of the starbord engine. My depth sounder does not work and I am assuming it is the transducer. It looks like it has been permanently glassed over. Is this normal? How do I test it? How do I replace it if that is what it needs? Any help would be appreciated.
chewy1955 05-29-2007 07:31 AM
ttt
c_deezy 06-01-2007 03:55 PM
Most depth finder transducers can't shoot through the coring in a hull, be it balsa or other, why I don't know. So most boats have a spot in the bilge, about as close to the bottom of the boat as possible that doesn't have any coring, it's all fiberglass, where you can mount a depth sounder transducer using epoxy or rtv. If you have twins it will be a ***** to find it.
chewy1955 06-05-2007 09:28 AM
Thank D C I guess I'll get a new transducer and try it first before I do anything with mine. Mine is located just forward of the starbord engine (98 Gun). It looks like someone added it there. Does anyone else have one in the hull of a Gun? Or maybe I should ask, is there a "factory" location on a Top Gun hull for a transducer?
