Help With Props On 35 Playboy
HAVE A 2001 35 PLAYBOY T/S. ENGINES ARE 500 EFI DYNO TO 525HP . RIGHT NOW I HAVE A SET OF BRAVO 1 30-4 B LADE AND AM GETTING MID 70s @4800 RPM. NEED SOME FEEDBACK ON WHAT PROPS AND WHO IS OUT THERE DOING GOOD HI-PERFOMANCE PROP WORK. THANKS FOR THE HELP
I have a 02 TS 35' Playboy with 500 EFI's and am using Bravo 1 Three blade 28's and get low 80's at 5100 rpm.
Sounds to me like you have to much prop |
Originally Posted by 2fun
(Post 2388573)
second we need more info... props spin in or out? what r u trimming the drives out to? mine ran 80+ with 4blade mercs... had some labbed picked up a few mph... then got labbed 5 blades 28 pitch and got 83 mph and awsome cruise... 60 at 4000 h2o toi r u really running 3 blade? |
2002 Playboy TS w/ 500EFI's
30P 15" Labbed maximus by mercury Runs 82-84 @ 5100 No mods to engines, Bravo xr drives 3400RPM= 56-57 mph 4000RPM= 63-64 mph Props spin out. No reason to switch them. Maximus will give you plenty of stern lift. |
Originally Posted by boater1
(Post 2388746)
30P 15" Labbed maximus by mercury Runs 82-84 @ 5100 No mods to engines, Bravo xr drives 3400RPM= 56-57 mph 4000RPM= 63-64 mph Props spin out. No reason to switch them. Maximus will give you plenty of stern lift. props in u want bow lift...thats the prob with 5 blades too much stern lift |
That they do. Doesn't appear to be that severe though. But could right away see the diff. when switched from 4blade bravos.
Another problem that may or maynot have been related to 5blades. More stess on drives. Blew top cap off yesterday afternoon. Starting the new year with a new drive...... |
thanks for all the info= props spin in ; drives are at mid range on guage. in regard to the 3 blade vs. 4 blade any control issues? had aset of 30 4 blade bravo 1 labbed and the so called pros screwed them up . this help is great hate to waste money and boating time
if yoou have the sticks all the way forward and are only turning 4800, then you are over propped, you should be able to spin to 5200 easily. I think the standard merc rev limiter is 54-5500., if you go with a 26-28 4 blade you should be fine. try them both and see which gives you best characterestics. I got my 26's labbed from BBlades and he did a great job, my straight hull tiger didnt like them, I wwent to 24 stock 4 blades and it ran like a dream.
(Post 2389152)
u need to trim the boat out... 6.5 to 7.5 on the drives... |
also "pitch" is different with different brands
boater1s 30 pitch mercs r the same as my 28-29 pitch hydromotive p5x |
| All times are GMT -5. The time now is 10:14 PM. |
