-   -   38 Cig Ts 2001 Props ??? (https://www.offshoreonly.com/forums/cigarette/181341-38-cig-ts-2001-props.html)
hangem out 2dry 03-04-2008 11:40 AM
I Have A 2001 38 Ts Top Gun With 500 Efi No Extension Boxes With Lab 32 Turning 4900/5000 At 80 Mph.this Is How I Bought The Boat.i Think It Came With Lab 30's. Any One Have This Setup,what Are You Running?
dreamer 03-04-2008 12:45 PM
labb 32s r too much prop... labbed 30 4b or a labbed 28/29 5b should do it... u need to get to 5100 rpm at least id think
Blue by You 03-04-2008 07:07 PM
I think it's 200 rpm's per pitch? Isn't it?
Try the prop slip program on BAM's website. It will help.
BillR 03-05-2008 07:12 AM
You need Brett @ Bblades to take a set of 30's and make them 31's. Then adjust them so the bow is carried a tad more. Should run 82 - 83 if the motors are strong.
Or try to have the 30's flat bladed and a small amount of cup removed.
Both of the above will likely be faster.
dreamer 03-05-2008 07:57 AM
call tom at hydomotive for some vo bs info... also brett at bblades too
Zero Patience 03-05-2008 04:40 PM
I have a perfect set of Merc Labbed 30s, and standard 30s if needed.
Top Ven 03-06-2008 03:15 PM
We have almost the same boat but it is a 02, with 500EFI with 28 s props that turn 5 200 rpm, & run 82 mph, gets on plane great !
H20 Toie 03-06-2008 03:19 PM
Same with my 02 Playboy except i have hit 84 a few times
