-   -   Depth finder suggestion (https://www.offshoreonly.com/forums/cigarette/183080-depth-finder-suggestion.html)
MickeyBoy 03-27-2008 05:01 AM
3 Attachment(s)
On my dash I have a depth sounder , broken !
I have to change it ...
As I understood , a depth sounder don't give me the depth..it just beep only to a certain depth ...correct ??
So I'm looking for an instrument who tell me the depth not only in feet , but also in meters ..
What do you suggest ? I've found out these 3...
NORCROSS @ $ 99.99
HUMMINBIRD @ $ 82.99
FARIA @ $ 174.99
I DON'T WANT TO DO HOLE THROUH THE HULL !!
dreamer 03-27-2008 07:17 AM
i have an extra... i look for it today and post a pic
omerta one 03-27-2008 11:25 AM
My depth gauge does not always work at speed...air under the hull. I understand that there is a model in which the transducer is set in oil or something to eliminate the air problem...but the cost is about $3 grand.
MickeyBoy 03-27-2008 11:43 AM
too much $$
In Italy we have a lot of rocks that you don't see , and depth change very quickly .
I think my one (broken one) it's only a depth allarm .
I need a depth finder ...
Elite Marine 03-30-2008 05:32 PM
Livorsi !!
http://shop.elitemarineonline.com/pr...3&productId=90
Use code OSO2008 for another 10% off.
dnebo 03-30-2008 09:33 PM
2 Attachment(s)
I have an old gauge if it will plug into your cable you can have it cheep.
Make me an offer. It may not be worth the shipping.
thisistank 03-30-2008 09:38 PM
Mike, if you don't take Darren up on his offer, do like Pantera said and get the Livorsi. We have that one in ours and it's great! Problem with using depth finders to help not damage your props is it's usually too late since it's mounted at the transom!
Darren, what up!?
dnebo 03-30-2008 09:52 PM
Darren, what up!?
Tank everything is good I am waiting for the snow to melt so I can put the boat in the water.
Now that the boat is done I figure I can help someone that needs some gauges and panles. If I can get rid of this stuff I can clean out my garage.
thisistank 03-30-2008 10:07 PM
For another toy!? :D
You sending the boat back out to Fl. this year?? Kelly and I may need a ride at some point:drink:
MickeyBoy 03-31-2008 01:54 AM
Darren, what up!?
Tank , that's only an allarm , or it's also a depth finder ??
Depth SounderDepth Sounder with alarm. 2-1/16 Cutout, 2-3/8 Overall. Liquid crystal display - 0-599 Ft. Shoot-thru-fiberglass or transom mount transducer. Shallow water alarm - from 3 - 20 Ft. Programmable keel offset.
And it says only Feet or also Meters ??
Ex. if I stop in the middle of a bay to swim ....:cool-smiley-011: , does it says the depth ???
U all !!!
