-   -   Cafe head (https://www.offshoreonly.com/forums/cigarette/183767-cafe-head.html)
Cigaretteski 04-04-2008 08:11 PM
Cafe head
Being a first time cigarette owner I am not sure the correct operation of the head. Is there any certain steps to follow bringing it out of winter storage ? Thanks
SKRAMER 04-04-2008 08:58 PM
Pump the anti freeze out of the water tank and holding tank. fill the water tank with water. you should be good to go after you put chemicals in the holding tank.
Cigaretteski 04-04-2008 10:19 PM
How much chemicals does the tank hold?
SKRAMER 04-05-2008 06:55 AM
My holding tank is very small. I only dump a small amout of chemical in at a time.
Cigaretteski 04-05-2008 04:29 PM
I'm not sure the where about of that small holding tank. Now the big water tank is on the port side. The small tank is where? I tried the small sink, which worked, but when I pushed the flush button for the head nothing happened. There is fluid in the bottom of the toliet, which I saw. But when I depressed the button to flush nothing happened, not even a sound.
stecz20 04-05-2008 10:06 PM
i have some paper work on the heads in a cafe.... i could fax it to ya.. let me know.. i had the same issue had no idea about it at all, someone sent this to me.... stecz
Sea Haggy 04-06-2008 12:54 AM
Retard, You better get that head working if you want me and Joyride hanging with you this Summer!!!
SKRAMER 04-06-2008 12:56 AM
Your holding tank is under your feet when you are standing at the helm. There should be an access panel in the floor.
Cigaretteski 04-06-2008 07:35 AM
That would be great, I'll have to find a fax number for you, thanks very much.
Cigaretteski 04-06-2008 07:36 AM
I'll check out that acess panel today thank you
