Originally Posted by Chris Sunkin
(Post 2540357)
One other thing...
Hopefully you've had the boat surveyed and they did a moisture test. If not, the Cig 35's all have one bolt per tab that doesn't nut on the other side. It screws into the end of the stringer- it's a stainless lag bolt. This is a common place for water intrusion and subsequently rot. Especially if the tabs have been removed and the bolt wasn't re-sealed properly If you haven't had a survey done, the best time to do so is before $$ changes hands. A transom and stringer job is pricey and May isn't the best time to start one. |
You can just pull the bolt out. If it comes out covered in sealant, you're probably OK, especially if it passed a moisture test. If it strips and then pulls out moist black crumbly stuff, you have an issue.
If you pull it, make sure you reseal the living hell out of it. Inject silicone deep into the hole- make sure you don't over-tighten it. |
Congrats and welcome to the family....
Originally Posted by oreo11zeus
(Post 2539469)
WELCOME TO THE CAFE CLUB!! - Hey, wondering what props/pitch your running..
Enjoy the best affordable boat ever made!!!! |
| All times are GMT -5. The time now is 11:37 PM. |
