-   -   Planeing Question 02 38 TG (https://www.offshoreonly.com/forums/cigarette/188025-planeing-question-02-38-tg.html)
nova26 06-02-2008 11:12 AM
Buddy of mine just bought a TG and it has merc 500 na's in it. He say's it takes along time to get up on plane. He had a 36 outlaw before. I've never drove a 38 before but don't you run the tabs down till you get on plane then bring them up as desired? It's at the 4mm @ LOTO.
Sea-Dated 06-02-2008 11:19 AM
Yes, drop the tabs all the way down and once the nose starts to come down, start bringing the tabs up.
Chris Sunkin 06-02-2008 11:32 AM
You may not need full tabs down. It depends on props. If it's got 3-blades and alot of pitch, full tabs adds enough drag to make it hard to keep from blowing them out when coming up.
I would try several different positions and see what works best. There are many variables and whoever propped it originally may have made some tradeoffs for top-end speed. If that's less important to you, consider swapping for a prop that could give you less cruising speed slip and easier on-plane performance. Depending on the prop, you may be able to improve it somewhat in all areas of performance.
nova26 06-02-2008 11:46 AM
Thanks guys! It will be my first ride in a cig. Stoked!!
Schweeng 06-02-2008 11:50 AM
Does this boat not have 4 blade 30's??
I had a T/S (525's) with 32's and didn't need any tap and the boat got right up and rolled over...never needed any tab.
Wild 06-02-2008 12:22 PM
is it white and blue
Top Ven 06-02-2008 01:54 PM
i have a 02 38 ft with 500 EFI s and have no trouble to get on plane, wheni havea full tank of gas or lots of people i put the tabs all the way down
nova26 06-02-2008 04:14 PM
Ya. In the cove just before The Duck in the back on the left.
nova26 06-02-2008 04:24 PM
I don't know what it has for props I'll find out. I think it has XR for drives. He bought it in FL. It's a Burgers marina now, one eng started pop n and the other started miss n.
Chris Sunkin 06-02-2008 06:41 PM
Originally Posted by nova26 (Post 2577398)
... one eng started pop n and the other started miss n.
I wouldn't be too worried about props. Sounds like the issue is elsewhere.
