-   -   Compass change 03 TG (https://www.offshoreonly.com/forums/cigarette/190102-compass-change-03-tg.html)
Boater0979 07-01-2008 10:15 PM
So this weekend my compass decided to leak all the oil out. Can it be removed from the top, or is it secured from under the dash too?
Also, where can I get one that fits?
BillR 07-02-2008 06:43 AM
Pulls out from the top. Held in w/ 3 screws.
Call MFG (Look on the compass card for mfg) and get replacement.
bcschoe 07-02-2008 08:19 AM
They can be repaired as well. If the coating does not need to be redone you are better off having it repaired.
seahawk 07-02-2008 02:28 PM
Go on line have the company send you the oil and the diaphram about $40.00. Also check the "O" ring in the fill hole. Should be a C. Plath / Merkur $714.00 for replacement :( . Good luck
Boater0979 07-02-2008 03:29 PM
Thanks for the good info. It sounds like repair is the way to go. I didn't know you could repair them. Anyway, I took the three screws out but its still stuck. It looks like maybe it was put in with silicone around it or something. I'm afraid I'm going to scratch up the housing trying to pry it loose.
dnebo 07-02-2008 03:50 PM
I also refilled and replaced the seal in mine for under $50.00.
Roger 1 07-02-2008 04:21 PM
I need to rebuild the one out of my 93 gun as well. I googled c.plath and found the site but could'nt find where to get the parts. Could you post a link when you get time?
Thanks in advance
Roger
Holy Smokes 07-02-2008 04:30 PM
Try this guy out west. He rebuilt my old 1979 era Danforth last summer.
Island Marine Instrument Co, Inc.
Everett, WA
425-258-4120
www.islandmarineinst.com
dnebo 07-02-2008 04:53 PM
Thanks in advance
Roger
As I recall I just called the manufacture had them send me a new O ring and I ordered compass oil from the local marine supply store. Ask for compass oil.
I belive I have a Ritichie compass in my boat.
I would not send it out unless you belive it is incorrect. Even then an adjustment is easy enougf to do. Use a gps or another compass to make your adjustment.
Roger 1 07-02-2008 05:42 PM
Thanks guys. The fluid drained our of mine while it was sitting here in my office. I'm affraid to ship it without fluid and damaging the card and internal components.
Roger
