-   -   Bullet Props (https://www.offshoreonly.com/forums/cigarette/209653-bullet-props.html)
brklink 05-27-2009 09:34 AM
Bullet Props
What kind of props are you guys running on your bullets??
Have any of you tried Clever props on a bravo set up??
Hollowpoint 05-27-2009 01:53 PM
I've never had the time and money to try different prop setups but I run 27P Mirage 3 blades at around 5100. Low to mid 70's.
DORaymond 05-27-2009 04:49 PM
I am running Mirage Plus 25P turning out. 5000rpm @70mph
BAREFOOTING 05-27-2009 06:23 PM
Mirage Plus 29 3blades 3/4 tanks of fuel 86 at 5000 hoping to hit 90 with light fuel Running a pair of 575s with xr drives,the 3 blades give great bow lift,alot of people use 4 blades to help get on plane quicker.
BAREFOOTING 05-28-2009 07:40 AM
[QUOTE=BAREFOOTING;2874338]Mirage Plus 29 3blades 3/4 tanks of fuel 86 at 5000 hoping to hit 90 with light fuel Running a pair of 575s with xr drives,the 3 blades give great bow lift,alot of people use 4 blades to help get on plane quicker.[/QUOTE excuse me,4blades will help you get on plane easier.
brklink 05-29-2009 08:51 AM
Thank you guys hollow point what kind of power are you running ???
Barefoot are your drives 1.5?? we have very simmilar power i have a set of 565's with 1.5 gears and bravo 1 22 pitch props at 75 mph the bow falls and i loose speed. are the mirrage plus props carrying the bow high above 75??
BAREFOOTING 05-29-2009 09:47 AM
Drives are 1.50, lots of bow lift,4 blades would make getting on plane better,what rpms are you turning with the 22s?
brklink 05-29-2009 10:07 AM
About6100 looking for 5600 rpm
BAREFOOTING 05-29-2009 12:12 PM
I would try a set 29 3 blade, or 28 4 blades,get a base line and go from there.Those props should bring your rps down to what your looking for.Its all trial and error. P.S.Does your hull have a keel pad? or straight bottom?
brklink 05-29-2009 01:11 PM
Thanks for your help it's a straight bottom
