-   -   factory electric fuel pumps in a 93 TG?? (https://www.offshoreonly.com/forums/cigarette/214245-factory-electric-fuel-pumps-93-tg.html)
eichhoma 08-04-2009 10:41 AM
What are the fuel pumps Cig used as stock on a 93 TG?
I can picture them, black, cylindrical pumps mounted to the lower wall in the engine room.... Who made them? What are good replacement pumps for this application? stock 525sc's for the most part....
thanks!
Biggus 08-04-2009 11:40 AM
I think the stock pumps back then were Stewart Warner. I've had great luck with the Holley "Black" pumps.
-Kurt
eichhoma 08-04-2009 12:16 PM
so, in looking at the holley blue and black pumps.... they are rated in GPH.... I dont know what mine are. I know I am at about 7.5 - 8.0 PSI at the carbs, but what flow rate do mymotors need? they are 502's with TBS 250's making 5 lbs of boost. Thanks.
Biggus 08-04-2009 12:25 PM
-The Black pump will work fine for your application. The Blue pump has had reliability issues.
eichhoma 08-04-2009 12:53 PM
cool, so no regulator needed? this will be a direct swap for my factory pumps? thanks gus
Zero Patience 08-04-2009 04:48 PM
I would run the regulators...
Biggus 08-04-2009 06:36 PM
Yup, the black pump requires a regulator but I'm pretty sure it comes with the pump.
eichhoma 08-04-2009 08:12 PM
Thanks fellas, I appreciate the info!
greg bakker 08-04-2009 08:30 PM
yep, go with the holley blue or black pumps they do come with the regulators. (use them) when you notice they are getting louder replace them right away dont wait for them to burn out. greg
eichhoma 08-11-2009 12:34 PM
I looked real closely at the fuel pumps that are in there.
They say Walbro on top of them. I cant make out any of the writing or engraving on the sides of them though. Judging by the looks of the rigging, I am assuming they are the stock / original pumps. Anyone know anything about these? What flow rate they have? Model #, etc? Just want to pin down exactly what I have in the boat now. Thanks.
cigrocket 08-11-2009 03:00 PM
I would go with the black ones like Biggus said. I few boats ago, I had a set of Blue ones in my Sonic. Within one season, I replaced them both. And had an issue with a new blue one also. Just my two cents. That was 5 years ago. Good luck
Kurt
dmaxx3500 08-12-2009 10:19 PM
my 91 42 revo had 3 mallory pumps ,1 mounted on each eng[carbed],running in parallel with the mech block pumps,,mallory rebuilt these for 1/2 of buying new ones,and these used regs too
