extension box help
I have a 1984 38 flatdeck with #3 I would like to know if extension boxes will help me bring up my X dimention I would like #5 but extension boxes would be much cheaper
Thanks jay |
Correct me if I'm wrong (masses) but extension boxes will atually lower your X. Drives are on an angle to the transom and the boxes push them out; i.e. down further. Unless you're getting those adjustable boxes where you can adjust the X.
(Post 2973924)
#5s and boxes would be my choice. But its not inexpensive.
Kris |
2 Attachment(s)
Kvogt is correct, to convert to box's and #5's is not going to be cheap, but it is well worth it, in my opinion.
I have everything that you need to convert to box's. Drive-line transmissions, Stelling's box's w/tailstocks. Gimbles and fresh #5 drives and a selection of 4bbl props. Call me if you are interested. Gary 763-473-8963 |
Thanks for the help every one Gary if I can sell my set up I will call
Thanks Jay |
Originally Posted by RMPRam
(Post 2974075)
Did the notch in the transom help anything as far as ride ,speed or getting on plane
thanks tony |
jay let me know if you still need parts for your motors....got lots for sale....
Im told there are two types of boxes....(1) that will lower the X dim and (2). one that will raise the X dim. Sooo does anyone know which ext boxes raise the X dim??? who makes and sells them??? P.S these are for #3,3a,4&5 drives.....
| All times are GMT -5. The time now is 04:37 PM. |
