#3a's to 5's
1999 Top Gun Cigarette.....Can i swap my 3a's for 5's....???? Will i be able to get the boat up on plane?? How come we dont see many Top Guns with 5's. is there a reason for this??? What would be some advantages and disadvantages other than top speed?
Mine has 5's from factory and their GREAT.......they can hold big power...our's is staggered and has twin 1200's
Mike |
what about putting boxes on your 3 a's? raise your x dim. then you have the same thing. they are almost the same drive, just a little longer with the 3a.
Originally Posted by thedonz
(Post 2986183)
Mike I believe one was "Fat Boy" Another I've seen pics, but can't recall the name? |
Carl's, Pure Pressure has Big Chiefs with Staggered #5s
who makes boxes that will fit 3's??? will 3" be high enough to make a difference??
I don't get the desire to put boxes on 3's....All that's going to do is DROP THE X. If you're going to put boxes on and raise your ex, just swap the drives for 5's like you wanted to in the first place. 5's will raise your x over 3's with out cutting the transom (shorter vertical shaft).
I would say if you swapped out your 3's for 5's you will see: A) longer time to plane B) Little more top end C) Props coming out more often in rough water D) A SWEEEET rooster! |
(Post 2986306)
I would say if you swapped out your 3's for 5's you will see: A) longer time to plane B) Little more top end C) Props coming out more often in rough water D) A SWEEEET rooster! I also thought about doing this but not enfough positive gain. |
do 5's with a inch spacer
Originally Posted by Comanche3Six
(Post 2986203)
Factory staggered.....
I believe one was "Fat Boy" Another I've seen pics, but can't recall the name? 1. ours...which now has cheif 1200's and 24inch boxes 2. Carls Pure Presure with cheif 950 3. fatboy 4. the spider boat 5. it's in Europe some where last i heard Mike |
Donz,
a friend is considering buying the 1990 gun at national liquidators, it is cut for 6's....curious what type of speed you see at 4000 and wot with your power set up... Thank you Shane |
4000= Mid 80
WOT= 107insh best ive seen right under 112 Mike |
4 Attachment(s)
(Post 2986664)
There was 5 staggered top gun made between 91-93
1. ours...which now has cheif 1200's and 24inch boxes 2. Carls Pure Presure with cheif 950 3. fatboy 4. the spider boat 5. it's in Europe some where last i heard Mike First staggered T/G was my 90. Campaigned for Cigarette in 89 by Mark McManus when he was at Everglades Marine. Then sold and Tres Martin maintained it for years. They are incredible boats. Fat Boy raced in Europe and I think Carls but don't think there was a 6th one. Be careful when you mess with the drives on a Top Gun. Cigarette has spent allot of time making them perform perfect with the setup it came with. The usual problem with switching to box's, 5's, both and going to #6's is porpoising. Not really a big deal. Drop the tabs a touch, scrub off a couple MPH but after a certain speed 70-75 you can start taking them back up and then look out. |
Originally Posted by Jesse James
(Post 2986934)
Donz,
1 Attachment(s)
I have been on this boat and run next to it on several poker runs and if someone is looking for a Gun with #6's this should be the one. http://www.offshoreonly.com/classifi...o30929-en.html
(Post 2986664)
1. ours...which now has cheif 1200's and 24inch boxes 2. Carls Pure Presure with cheif 950 3. fatboy 4. the spider boat 5. it's in Europe some where last i heard Mike That was it............awesome Cig! |
What about the Konrad drive, they claim that is the hot lick drive when wanting a higher x dim. and a stronger drive over the 3a ?
2 Attachment(s)
(Post 2987757)
Pure Pressure!
Originally Posted by inbetween
(Post 2987809)
Mike |
Originally Posted by Doug
(Post 2987413)
Be careful when you mess with the drives on a Top Gun. Cigarette has spent allot of time making them perform perfect with the setup it came with. The usual problem with switching to box's, 5's, both and going to #6's is porpoising. Not really a big deal. Drop the tabs a touch, scrub off a couple MPH but after a certain speed 70-75 you can start taking them back up and then look out. I know that there wasn't 6 only 5....Carl's boat was built to race in Argentina but it never did race. His is also the heavest one built because of the rough water over seas. so i guess they are all here in the states than :drink::drink: Mike |
(Post 2987413)
(Post 2987296)
4000= Mid 80
WOT= 107insh best ive seen right under 112 Mike thanks |
so what speed increase am i looking at with this swap?....10-12mph?
Originally Posted by bigfarmer
(Post 2990317)
If you run in the mid or upper 90 MPH range I think that is very respectable. There are some production/cookie cutter boats out there that will run well over 100MPH with your power if speed is what you are looking for. What ever you decide keep us posted I will be very intrested in the final results and good luck. |
2 Attachment(s)
To give you an idea, 3800 RPM is an honest 65 mph GPS in our side by side No. 6 Gun. The drives could be raised by removing the one inch spacer, if top speed is your primary goal. Figures I would pick up some trash in the speedo pitot tube the day we took the pics. 5000RPM puts you up around 85 mph.......and 5600 RPM at WOT is all relative :D :
| All times are GMT -5. The time now is 10:37 AM. |
