-   -   Transom assemblies? (https://www.offshoreonly.com/forums/cigarette/219827-transom-assemblies.html)
2112 11-09-2009 11:33 PM
Transom assemblies?
Anyone know if (on 04' and newer models) the factory uses 5200 or the like to "glue" the transom assembly to the outside of the boat?
Smitty 11-10-2009 11:23 AM
I don't think any sealer is used. If they did it would be ugly if you had to take one off.
2112 11-10-2009 11:25 PM
Well, That is what I am hoping for but I would sure like to know before I start trying to take it off. :eek:
I was hoping someone out there knew first hand.
OL40SVX 11-10-2009 11:41 PM
Our 2003 didnt have anything like that. We removed them ourselves.
2112 11-11-2009 12:00 AM
Did you have ITS? Is there a gasket/O-ring?
Should have know to just contact you first. :drink:
OL40SVX 11-11-2009 06:22 AM
1 Attachment(s)
yes ITS, O ring(sort of) p/n 437131
seafordguy 11-11-2009 11:02 AM
I believe they are large foam gaskets. I think they are simliar to Bravo's.
If any manufacturer ever put them on with 5200 every transom assembly removal in the world would make for some Glass work.
When I put my assemblies back on I used the foam gasket, and I actually went a little farther and used a nice bead of clear caulk around the assembly on the outside.
2112 11-11-2009 03:03 PM
What brand of caulk?
Yeah, I do not want to try and pull it off if it has adhesive. 5200 is miserable to remove as I am sure you all know.
