Turn em in anyone?
i have a 38 top gun 2003. Anybody ever try turning props in? more speed-handling?
Rob(offshoredrillin) did that to his 42 Tiger this past summer, has some good speed increase!! Im sure he will chime in to tell you the results!
yep got 3 mph out of it, handling is the same, turning in provided the bow lift I needed. however mine is a straight hull. check with lipship or Tres martin as to the pros and cons of it with a step hull.
I just switched them first to see if I would like it, then when i did I had the cables changed. |
WMF dod you ever try to spin in with your mystique?
I had them spinning in in my top gun (Straight Bottom) Picked up a little and felt more stable
Originally Posted by Boomer35
(Post 3022906)
Okay I don't want to hi jack your thread but I am wondering if I could benefit from turning them in. 93 Cafe running 26 labbed props boat runs 78-79mph. Would love to get 80 on GPS. What is the downside? I would imagine docking?
(Post 3022882)
Originally Posted by 4195
(Post 3022954)
If you are only chasing one mile an hour, I would talk to BBlades and see what they can do for you. You say you have labbed props, but Brett seems to be able to squeeze 1 or 2 MPH when you want to get it done. Also depending on x dimension, maybe you can put shorties on. Sometimes, Cigarette is conservative with the X dimension. Good luck |
So any T/S players?
(Post 3022955)
Offshore what are you running for power and mph?
So for me it was worth it, I will put on labbed props this summer to see if I can get any more, but who knows. |
Originally Posted by cigrocket
(Post 3022973)
I had a 35' mistress, no notch. Konrad Drives. By spinning in I gained 4-5 miles an hour. The docking was an issue and I new I didn't buy the boat to be the fastest. It ran an honest 75 all the time spinning out. Ran 78-79 spinning in.
my 35 t/s i had em in and picked up a tick but it has no notch... notched 38 t/s spin out per the experts and running in snot
The props on my my 39 Top Gun are turning in (staggered engines). We also had them turning in on the 2000 Top Gun (TS, side by side) and 2003 Gladiator (staggered engines). All three of these were set up with the props turning in from the get go and I never tried them with the props turning out so I cannot tell you what difference it will make. I can tell you that they do work fine turning in on a twin step though.
As for a straight bottom, we tried the props turning out on my old 45 Apache before we decided to turn them in and leave it that way. Turning them in provided the boat with more bow lift and it actually seemed to handle better as well. |
If someone doesn't mind a rookie question...
What does it mean to "turn in" your props, and why would it effect docking? |
Originally Posted by wjb21ndtown
(Post 3023325)
What does it mean to "turn in" your props, and why would it effect docking? Starboard prop turns CCW, port turns CW. ( when viewed from the rear) Reverse seems to have less effect than when they're turning out. I've found that leaving the drives trimmed slighly positve helps handling a bit, when turning in. |
(Post 3022954)
Big difference on mine. Turned in last year and gained 4mph top end. '01 Tiger straight bottom. 750hp ea side by side with IMCO Extremes and extension boxes. No problems docking.
Originally Posted by Expat
(Post 3023458)
(Post 3023503)
nice! whats top speed with the 750's? what type of boxes? straight back or upswept..any pics?
Pics and more numbers soon. |
(Post 3023668)
Staight back boxes. I just put the engines back in from a full Ron Potter rebuild and only have about three hours on them so I don't have top end #'s yet. Before the rebuild and I think about 50-75hp less per side my gps top end was 86mph. I sure am hoping for 90mph but........
Originally Posted by SKRAMER
(Post 3023357)
I'm spinning in. (89 Cafe) Better all around except around the dock. Docking will take getting used to.
What are you seeing for mph? LOve that boat I am gled you refuse to give it away. |
Guess I am going to have to try it. I have stelling boxes to.
| All times are GMT -5. The time now is 06:49 AM. |
