-   -   Cafe switch wiring issue (https://www.offshoreonly.com/forums/cigarette/231765-cafe-switch-wiring-issue.html)
crt35 06-01-2010 06:07 PM
I have an '87 Cafe Racer and recently replaced all the switches on the dash with Carling Contura II switches only to find out that my notes were substandard. Currently the electric fuel pumps are not working, nor is the hatch switch. This has me second guessing my work as a whole.
I'm a little green when it comes to electrical issues and am looking for someone who may have taken pics of how the switches are supposed to be wired, or spell it out in layman's terms.
Thanks for the help!
seafordguy 06-01-2010 06:16 PM
Email me at eric.ancarrow (at) ferguson.com
I have copies of some the original documents that I think might be helpful to you.
Sick Stinger 06-01-2010 09:10 PM
I have a wiring diagram from the factory i have an 87
-Mike
Panic Button 06-02-2010 06:53 AM
I can scan the wiring diagrams and post them as PDF's when I get to work today, if you still need them.
Panic Button 06-02-2010 08:29 AM
5 Attachment(s)
This might help
BDiggity 06-02-2010 10:45 AM
Thanks! this will help me troubleshoot my engine oil temp gauges.
crt35 06-02-2010 04:34 PM
Thanks for the replies everyone, the information provided is much, much more than I could have hoped for.
I'll keep you updated on the progress. Cheers! :ernaehrung004:
crt35 08-13-2010 07:45 PM
I've been able to make some headway with the switches although progress has been a bit slow. Utilizing the diagrams that seafordguy sent me (thanks Eric!) I started working on the switches from right to left because the wires on the right in my opinion were easier to decipher and reconnect. I swapped out the original ring connectors for spade connectors, soldering each new spade in place.
The following switches have been rewired and tested successfully;
Blower, Eng Hatch, Aft Pumps (Port, Stbd), Lights (all of them), water, #1, #2.
The horn has been wired but it's not working. It wasn't working when I bought the boat (an air-horn is in the glove box) and I'd like to replace the OEM horn but don't know where it's located.
The most difficult part has been trying to figure out how the key'd switch/start buttons/lanyards/fuel pumps are supposed to be wired. The diagrams above are great, however, they do not cover the key'd switches or Lanyards. Complicating things a bit more, sometime in the past someone did a bit of rewiring by disconnecting the lanyards and disconnecting Purple #3 and Purple #13 from the fuse block in the head (see the switch diagram in PanicButton's post above). I was able to find and Purple #3 and Purple #13 in the cavity of the console and track the back through the upper right side of the head where they were tapped off to the side. In the fuse panel in the head, I also found two purple wires cut at the top left side of the fuse block leaves me to believe each wire on the upper right was supposed to be wired to the upper block and the corresponding purple wire from the left connected to it. My question now is, where in the upper block are they supposed to be wired?
Thanks for listening, I'll try to get some pics tomorrow..
crt35 08-14-2010 11:12 AM
The pic below is the fuse panel in the Head, note the two purple wires with the blue tape on them, also note the two purple wires on the left side that had been cut. This was done prior to my owning the boat, all I've done is remove the clear Plexi cover to access the wires;
http://www.offshoreonly.com/gallery/...e=18267&size=1
crt35 08-14-2010 11:27 AM
Using the pic in the previous post (the top connection block) is it safe to assume that there is supposed to be a corresponding wire on the top for every wire connected at the bottom of the block?
thor thorsen 06-20-2015 07:05 AM
Hi could you email me the diagram?
[email protected]
