Originally Posted by UrbanDisturbance
(Post 3149779)
My supercharged 502s that produce 600hp each run a little hot. After cruising at 3200rpm for 15 minutes, my engines temp creaps up to 225-230. I slow down to idle and the temp drops to 185-190 in about 3 minutes. What is too hot. I use Mobile 1 15/50. Any input or advise?
Did you SC the engines from stock? if so you may need to add a oil cooler to each if you start getting past where you are now. sustained 245+ starts to get bad for your engine longevity. |
Oh yeah...
Dan Olson, Teague, CP, Rex, and other sell very high quality coolers.
I use an aeroquip my self. Cant get em anymore, but I wont ditch it until it doesn't work anymore which is hopefully a looong time. Uncle Dave |
Originally Posted by Uncle Dave
(Post 3150056)
some more questions- what happens when you leg it at 4000+ for some length of time? Where do they go then?
(Post 3150076)
The 250 B&M blowers were already on the engines. I replaced the 454 block with a Dart 502 block and had all new internal parts. I don't really run my boat over 4000rpm for a very long time... maybe 20 seconds. I have the old style 1 Inch bravo 1's and I'm afraid I am going to break them. I don't want to be out of a boat until I can afford some Arneson Surface Drives and add some more modifications to my engines to increase Horse Power. That's going to cost a lot!
Does that engine have iron heads? I'd lower my Water T stat to no higher than 130 , - or maybe even 100 if you run for long periods of time the risk under 130 water is moisture not burning off quickly enough and contaminating the oil. Arnesons are an awesome, but unconventional package, and as long as a boat closely matching your setup has been modded by them - you are golden. If not you could have problems (as you could have problems with any aftermarket drive not exactly matching what you have now) If your parameters fit an Arneson it is a very worthy investment imho. Uncle Dave |
BTW- there is a ton of argument about whats too hot with little agreement about the upper number.
some will tell you 280 is where things go bad other will tell you the oil companies rate their stuff to 330 Oil coolers "tend" (more controversy) to measure the drop from 280+ adding more controversy. (The department of redundancy department) - and absolutely everyone agreeing that cooler is better to the water boiling of 212. - so head for the low target. Uncle Dave |
I would look into a larger oil cooler with a thermostat inline. This system will will keep your oil at optimum temp. LIke stated before the merc. system in barely adequate at best. Adding the superchargers probably put you over the edge in the oil cooler department.
So what's too cold? My temp (taken from sender installed just in front of pad adapter) is 160-180. It has stock thermostat in adapter, I think 165*, but Merc could not confirm this.
Water never over 110, no thermostat per Whipple direction. |
Originally Posted by CIG3
(Post 3150102)
My boat runs at 130 water temp and 230 oil temp. |
Originally Posted by OldSchool
(Post 3157581)
IMO, 220-230 is damn near perfect for the oil temp. I mean....don't you want it to be more that 212 so condensation/dilution gets burned out of the oil??
don't you want it to be more that 212 so condensation/dilution gets burned out of the oil?? Conventional oils break down in the low-mid 200s, synthetics stay together into the 300s. And then they're burnt. |
| All times are GMT -5. The time now is 12:28 PM. |
