-   -   Prop Question (https://www.offshoreonly.com/forums/cigarette/235656-prop-question.html)
osen007 07-27-2010 09:01 PM
Prop Question
86 38 Foot Flat Deck Cigarette
1200 Hp Twin 468 Tall Deck BBC's 600h.p. a piece Jomar racing built them.
Trs out drives 1.5 to one.
Bassett Headers.
5k in steering off back.
I had 25 pitch 3 blades it would only turn 4700 rpm and run around 55-60. I went to 23 pitch 3 blades I can get 5100 rpm maybe running 68 mph. I have to gps it.
I thought with 1200 hp I should be able to turn a 23 pitch prop at around 5600.
I have the drives trimmed out at about 3 on the gauge?
I dont want to go to 21 because Ill be in the 4k range crusing and eating gas.
Any Ideas????????
rchevelle71 07-28-2010 07:09 AM
1200HP, and 23 pitch 3 blades at 5100??? Something is not right, my 250HP outboard can turn that same prop to 5400!!!!
BGIII 07-28-2010 07:13 AM
Your boat doesn't weigh 15,000# either.
UrbanDisturbance 07-28-2010 10:11 AM
You can't have 2 600hp engines. I have a 1994 Cigarette TOP GUN. It weighs 11,500lbs empty weight. Then I add 200 gallons of fuel, Ice Check and 4 people and I am most likely over 13000lbs. I have 2 supercharged 600hp motors. I have 2 26 pitch lab finished 5 blade Maximus props and I am hitting my rev limiter at 5500rpm. With non labbed 4 blade 26 pitich clever style hydromotive props, I still hit my rev limiter at 5500rpm.
rchevelle71 07-28-2010 10:14 AM
True, but he is talking RPM, those motors should slip the props like mad.
seafordguy 07-28-2010 01:34 PM
If it helps at all I have what I estimate to be about 575HP - Blown 502's and I spin 26-4 Blades north of 5100 rpms.
Granted this is on my Cafe, but hopefully it helps a little.
LV 07-28-2010 02:20 PM
I would try a 21 pitch 5 blade labbed Hydomotive!
that will help your cruise speed and slip problem your having!
osen007 07-28-2010 04:22 PM
I was told today weather in michigan makes a difference and that in june, july and august the boat will run 200 less rpm because of water temp and air quailty. My boat weighs 9500 lbs I weight 220 and I have 200 gallons of gas at 8 lbs a gallon. I will keep a eye on the tach as the gas gets low haha
Doug 07-28-2010 04:32 PM
5 Blades on a TRS. NOT Only if your on flat water and the boat never gets any air under it and still 4 blade would be the max.
frickstyle 07-29-2010 07:54 AM
What speed are you seeing (loaded) with the 26 pitch and that setup on flat water? Are you on TRSs? What's cruise speed? Are those blades labbed, Bravo 1 blades?
