Okay after much consideration and feed back from this thread I have made my decision. I am going with a naturally aspirated set up from Bob at Marine Kinetics (aka rmbuilder). A set of oval port AFR cnc'd heads custome ground cams and lifters and new carbs. We are shooting for around 625hp. My new question is what should I expect to pay to remove and replace the engines. I am wondering the true cost of pulling them out and rerigging later? Maybe I will just disconnect everyhting and have them pull the motors????
Originally Posted by 4195
(Post 3198354)
Ill do it for a 24 pack of gatoraid hold the mayo
-Mike |
1 Attachment(s)
The local marina to us charges 10 hours each engine. Having done it once myself, I think that is VERY excessive for "professionals". I spent about 500 bucks at harbor freight for a gantry crane, trolley and chain hoist and did it in my front yard....
Chain Fall off a 2" thick I-Beam runs across the width of my shop with a 1K chain fall and air tools. Pulled the engine in mine in about 2 hours lolly gagin around. 4150 you need somethign let me know
-Mike |
Originally Posted by Sick Stinger
(Post 3198690)
-Mike The engine hatch is heavy as ****... |
I tie my engine hatch up with a couple ropes to a beam behind the boat and the chainfall beam give the hatch about a 20 degree lean back so i can just pull it. Then I back my truck up and let the hatch close and pull the whole rig forward and drop the engine easy as taking a wiz.
-Mike |
Originally Posted by Dwane
(Post 3182908)
I had mine done back in 2003 if they are done right you shouldn’t have any problems
Hey frank vic here just going to give u my 2cents,I would go n/a all the way,again I have seen problems with supercharging ect,for the power u want I would go 540 withe dart pro1 heads,cosed cooling good exhaust and u will have a reaiable set up mine dinod at 600 plus they run alittle cool but 3years no prob they do need super though gd luck with it
Originally Posted by park35
(Post 3294128)
| All times are GMT -5. The time now is 07:22 AM. |
