-   -   Cafe Cabin entrance door latch receiver (https://www.offshoreonly.com/forums/cigarette/238957-cafe-cabin-entrance-door-latch-receiver.html)
seafordguy 10-12-2010 05:28 PM
Originally Posted by Sick Stinger (Post 3228763)
Didnt either of you guys get these things?
-Mike
Yes - I did mike. Received on Saturday I believe, but was at a wedding and haven't been able to pull the cover off yet and mount it. Looks like a nicely done piece!!
Thanks a TON.
Let me know what I owe you and how you want to get paid.
Sick Stinger 10-12-2010 07:53 PM
Sea make sure its all good and well. He did an excellent job on them he's a good guy helps me out a lot with stuff I need and reasonable since he is the only show in town.
-Mikie
ajacobazzi 10-13-2010 09:37 AM
Thanks a TON.
+1
THANK YOU MIKE!!!! Your guy did an amazing job on the fabrication. Regardless of whether or not it works, we still need to pay for them. Please advise as to how we should proceed with payment.........and how much. :)
Sick Stinger 10-13-2010 10:28 AM
No way they better work and until installed I dont want to get paid.
-Mike
ajacobazzi 10-13-2010 11:10 AM
-Mike
In that case, "Damn piece of ****!!! It doesn't work!!!" LOL!!!! Just kidding!!! I'm going to drop it of at the marina tomorrow morning. Hopefully, I'll know by the end of the week.
With your boat currently under renovation, I wonder if you could answer a question for me? I can't imagine that the piece that you sent me just secures into the fiberglass with self tapping screws, right? Is there some kind of backer on the inside of the consul that the screws screw into for support? Or, is it through bolted with a metal plate on the inside?
Sick Stinger 10-13-2010 12:30 PM
Sorry for disapointmnt screwed in. I kept all the hardware together and that is what i pulled out. And from what i remeber and I can go home and look after work i do not believed you can get to the back of it as its the bulk head between cockpit and cabin and its screwed into the bulkhead
-Mike
ajacobazzi 10-13-2010 12:54 PM
-Mike
Wow, no kidding, that's it huh? Crazy! You would think that there would be more than that. If someone wanted to "break in", all they would have to do is yank on the door hard enough and you'd pull the receiver right out of the bulkhead, no? Once the dash/gauge panel is removed, couldn't that area be accessed from that point?
seafordguy 10-13-2010 06:09 PM
Hey Ajocabazzi - just a thought I had the other day, but I am going to open one of my hatches the first time I slam the door shut - in case it needs some adjustment or something I want to be able to get to the inside of the boat in case the whole handle needs to be taken off or something.
Can't picture how it bolts together right now, so I might be WAY off base, but it crossed my mind......
excalibur27 10-13-2010 07:37 PM
Mine is just screwed in also. Even if you use a backing plate, a large enough pry bar will open the cabin door. I really think the screws would snap apart if someone used a large pry bar. If not on that part, probably snap the catch mechanism in the door. And that is why I don't even lock mine.
ajacobazzi 10-14-2010 11:16 AM
-Mike
Okay. Gave it a dry run this morning. Looks like it's gonna work just fine.
So, you just hold it up to the bulk head and screw it in place? It appears that a hole will need to be made in the bulk head behind the receiver, as the latch is longer than the receiver is deep. Follow me? Is that how it is on your boat? In addition, it doesn't appear that the door will close flush, as the thickness of the mounting plate on the receiver will hold the door open slightly, right? Since it's not counter sunk.
I suppose, once installed, weather stripping on the side of the door would fill the gap and help to prevent water from getting into the cabin, no? Maybe that's how it's supposed to be? Seems to make sense.
