top gun gas tanks sending units ???
just bought a 94 top gun . sending units are junk .i pulled them out today to ck .unit marked centroid products cgf-24 3 wire .they appear to still be around .also any idea how many gal tanks these are . ive been told anywhere from 100-120per side thanks guys
Should be 110.
I have a 94 as well 110.
Originally Posted by carter38
(Post 3232726)
Originally Posted by Quinlan
(Post 3232781)
And sometimes there is NONE in there!
It's also time to head for the gas dock, when they get down to 1/4 tank on the straight bottoms :eek:
Originally Posted by BLee
(Post 3232965)
I put a pair of these in the Bullet a few years ago and they've held up well.
http://www.hardin-marine.com/p-211-2...el-sender.aspx |
Originally Posted by Screamineagle
(Post 3233431)
set the sending units up so when the gauge reads empty you have a quarter tank, that way you keep from picking crap off bottom of tank and you know you have a little reserve when you should have bein at the fuel dock already.
Originally Posted by fastek
(Post 3233482)
looks the same as mine with the exception of 2 wires .mine has 3 wires .looking at the instructions to install it seems these have to be cut to fit or am i wrong ?? that being the case you should be able to make it so you dont run out of fuel @ 1/4 of a tank or is there another adjustment .my sender appears to have 2 small screws on top 1 says full other says empty
The two adjustments are to set your gauge, I set the empty before I put it in a the tank, which was full, then set the full after it was installed. So yes, you can set the gauge to read empty when there is 1/4 tank left by the empty adjustment. |
On a Bullet, Are you supposed to install the sending units in the tank with them folding front? or folding back? or to the side? Mine dont work properly, the readings on the gauges are all over the place. Where are these adjustment screws???
[QUOTE=kreed;3233712]On a Bullet, Are you supposed to install the sending units in the tank with them folding front? or folding back? or to the side? Mine dont work properly, the readings on the gauges are all over the place. Where are these adjustment screws???[/QUOTE
I think we're talking about 2 different things. I installed the aftermarket sending units from Hardin that have the adjustment screws/potentiometers on them for full and empty. They do not fold. |
(Post 3233685)
I measured the originals and ordered those already at the length I needed.
