-   -   Anyone ever cut the hook out of a 28? (https://www.offshoreonly.com/forums/cigarette/241373-anyone-ever-cut-hook-out-28-a.html)
THRILLSEEKER 10-28-2010 09:22 AM
Originally Posted by WOTW2E (Post 3240759)
Tony, barely 4600 seems WAY, WAY low. You know how the engines were built and the cam specs. Surely those small blocks can twist up more than that. I bet you're leaving 40-50 horse or more each on the table spinning them that slow. The hook is NOT helping in any way but I don't think that is the main problem either. Props dude, Props. Play with rotation as well. Spinning in (I think you said they were already) will help pull the stern down and the bow up.
The Vs that I have run did not like the design of the 25M+. There is something different in the casting of the 25 vs the 23 and the 27. It just does not seem to carry the bow as well and was more difficult to plane with. They just don't seem to bite as well for whatever reason. I am talking stock props here for the 23 and 25. The 27 was labbed.
I would HATE to have to add weight after all that work and expense to remove some of it.
Drives are currently spinning out. Sitting around wondering about all this over the winter is going to bug the **** outa me.
WOTW2E 10-28-2010 10:07 AM
Sun will be shinning this weekend! I'm sure I could round up some props for you to try. Call me.
stageharbor 10-30-2010 01:12 PM
my 28 has 7.4 mpi engines 310 hp and trs drives the back of my boat is certainly heavy. the water line is right at the molded turn in the hull. I run 27 mirage plus props and have a hard time keeping the bow down if my 30 gallon fwd tank is not full. so it seems as though you should be able to spin more than a 25 with 400 hp.
THRILLSEEKER 11-01-2010 07:06 AM
TRS drives?
4FX 11-07-2010 06:39 AM
Get rid of the TRS drives!! move the SBC's back and have B1's it'll be better in the long run can now also go to a big block with the added room.
Tony I went throught he same thing when I did mine. had an 81' but got it with nothing in it, other than holes.. I did the 600EFI's from AS&M which are/were 496's with Imco SC's.
Troy
Crallscars 11-15-2010 12:51 PM
My 28 SS with Merc 425's and TRS runs great, mine will spin to read line easily.
Most of these SS's have small blocks which is probably the same weight in back as yours.
Your drives and engines are fine, work on the props, maybe add fuel in the front tank.
