-   -   Heres one as I scratch my head (https://www.offshoreonly.com/forums/cigarette/257541-heres-one-i-scratch-my-head.html)
osen007 07-08-2011 04:46 PM
3 Attachment(s)
I had to change the headgasket on the starboard motor starboard side of block because it was leaking water out of the front of the block in between head and block. Water didnt not get into oil or cylinder. I will post a pick of gasket tonight just so you can see it is perfect, it like seperated right where the water jacket on the head is blocked by the front of the gen 4 block itself and the gasket seals it. So here is the order I used, I removed air cleaner, carb, distributor, intake, header, valve cover, spark plug wires, spark plugs, and than the Head. Then put it all back together.
I also lashed all the valves as recommended after every 20 hours on both motors. Cold lash on my cam is 21 intake and 23 exhaust. I watched it 10 times on youtube how to lash a solid roller cam and I work at a Cadillac dealer and bugged the old school mechanic 10 times to make sure I did it right and he used to race cars and was sponsord from Kendall back in the day so he would know how to do it right. Port motor still runs like a champ I lashed that one too. Here is the problem I having with starbord.
So I put it all back together and now I have poor throttle response and when it warms up it is backfiring through the carb under load at tempture, and I can only turn 4700-4800 rpm instead of 5200 like the other one, also getting like a white smoke color coming out of the valve cover vents after it warms up.
I check the advance timing 4-5 times it is perfect at 36 degrees full advance above 3200 rpm just like the perfect running port motor. I also changed the distribitor cap, and checked the firing order 2 times, checked my fuel water seperators they no water at all, The only thing I didnt check is when I took the plugs out to remove the header and put them back In maybe I cracked one? I dont know.
I took boat to my Mechnic I was stumped. He relashed the valves and he said a few were to tight on starboard motor. He didnt get a chance to run it because I dropped it off afternoon today. So after work I will run it and see. Would a valve or 2 being to tight cause this problem.
Remember it runs and idles fine in the well and down the canal, I just have poor throttle response and backfire through carb under load above 3200 going into higher RPMs, and after it engine warms around 140-150 degrese is when I get the backfire here and there.
I would not think I would need any new parts because the boat ran perfect before I messed with it.
Any thoughts meaning if I run it tonight after the valves have been correctly lashed by a professonial and Im still having this problem. so I can tackle them in morning.
Justin
586-524-3450
Call or respond.
Thaks Cigarette buddies.
kidapache 07-08-2011 06:43 PM
back fire from the carb is both valves open at the same time one could be bent. valve gides to tight. cam could be shot when the rockers are to tight check every thing
osen007 07-08-2011 07:50 PM
The mechanic said valves checked out fine when he lashed them. I noticed to today when I drove it that when I turned the key to on to hit the start button it was turning the gauges on anf off like a bad ignition switch. So I going to change that tomorrow morning and go from there.
88bullet 07-08-2011 08:23 PM
just had a simlilar problem on a fountain i was working on. 1 spark plug was fouled and the coil was on its way out. coil finally failed completely. replaced coil and spark plugs.. ran like a scalded dog. 35 dollar fix. coils like to be mounted vertical not horizontal
tfalk 07-08-2011 11:14 PM
If I had your money I would quit trying to fix it myself and hire someone who knows what they are doing. Your tried to be a marine mechanic years ago, you had a great teacher just couldn't pick it up, that is why you sell Cadillacs today. LOL
osen007 07-09-2011 07:47 AM
This must be Tim....
I call your dad fred all the time this has him scratching his head.....Ron at Dynamic Speed and marins says Its gotta be a plug or wire that went bad. So Im replacing that today Ill keep you informed
Griff 07-09-2011 02:42 PM
Intake valves are set too tight and hanging open.
osen007 07-09-2011 09:15 PM
I ran it hard pulled all the plugs on the lake they looked fine, then went to switching parts one at a time from motor to motor. the first thing I tried was the coils. I switched them now motors run fine.
tfalk 07-10-2011 08:40 AM
Are you sure the coil wire wasn't loose before you switched them?
Roger 1 07-10-2011 09:16 AM
There's your problem right there. You had the port and starboard coils switched........
88bullet 07-10-2011 09:20 AM
so do i win a prize??
osen007 07-11-2011 03:38 PM
The motors have 72 hours on them now and maybe a total of 85 before this winter. I will have Dynamic Speed and Marine take them out and freshen them up. I have another set of Trs's with nose cones I want to put on and also I want to have the engine compartment painted and freshened up :).
Its like a hotrod to me I dont care to drive it I just want it to look nice.
When I blew the drive last year the insurance adjuster couldn't believe it was a 1986 she said it looks alot cleaner than most 5 year old boats she see's daily. So I got nothing but time this long winter in michigan to Dial It In.
http://www.youtube.com/watch?v=wMzfQgOGcdM
osen007 07-14-2011 08:58 AM
I went to go for a rip last night same thing Popping through carb, poor acceleration. But it idles down the canal fine and revs up fine with no load. I had the valves set buy a professional last friday "TFALK you would know Bruce from Naughtical Mile Marine" he said that cannot be the problem it has to be electrical. I checked the firing order 3 times last night checking it with the Mercuriser Service Manual and off the other motor.
So its not the coil wire or switching the coils didn't solve the problem. I dont understand it ran perfect Saturday after I replace the coil wire going to distributor and switched the 2 coils around. I thought maybe I didn't have a good connection to the coil.
So last night I swtched the msd boxes around. It cannot be a valve due to it ran perfect saturday after I messed with switching the coils around and wiring. It is happing intermittently. Idles fine but underload is the problem. Friday I will have to update you guys. I work 9-9 today.
Anyone ever have problems with MSD.
On the good engine
Im running the MSD-7ML-2, Mallory 29625 coil, Msd Marine Distributor, New Cap and rotor.
On the problem motor the only thing different is the MSD propower HVC Coil, and now this coil is on the good engine after the switch and that engine still runs perfect.
The only problem is if it is the MSD box they dont make it anymore so I have to find one that someone is selling one or go to the MSD-7AL-2.
TFALK it would be stupid to pay someone 100 per hour to switch things around and test drive it. I would be cheaper doing the labor myself. Plus it keeps the wife out of my hair. From other posts it could be somthing as stupid as a hair line crack in a plug remember I had to remove them to replace the gasket. So If it isnt the MSD box the Motor will get all new wires and Plugs. Bruce said switch things one at a time and run it untill you spend any money on parts. Thats what I would of paid him to do.
RT930turbo 07-14-2011 09:45 AM
Hey Justin,
I just went through this with my engines, I assume you are running Thunderbolts with MSD boxes and MSD coils?
I have the exact same set up and it turned out to be the pickup in the distributor. It was the last think I tried since I was always under the impression that a magnetic pickup either works, or doesn't work. I had the same symptoms you are describing and after switching out the pickup it cleared up all my issues.
Worth a shot and a cheap fix if you haven't already tried it...
Do both sides if it's the culprit, my other pickup failed less than 5 hours later. Same symptoms.
RT930turbo 07-14-2011 10:52 AM
1 Attachment(s)
Justin -
The MSD Distributors should have a pickup under the rotor. Kind of hard to tell from your pic but this looks like it -
here is an example from Summit on what a pickup looks like, just be sure to check the part # on the distributor so you get the right one.
http://www.summitracing.com/parts/MSD-84661/
Good luck!
osen007 07-14-2011 11:02 AM
Originally Posted by RT930turbo (Post 3452657)
Justin -
Good luck!
Im goint to go home at lunch get the dist # and just order 2 I like having extra parts just incase
CIG3 07-14-2011 12:52 PM
Before you spend the bucks to buy a new complete distributor check a couple things.
First check to see if the mechanical advance is working properly not stiff.
Second look at the pick up and trigger wheel (Reluctor) to make sure they are not rusty. If they are replace them.
The internal parts are the same on all MSD stuff and not really suited for Marine environment (Moisture).
Good thing is the box either works or it doesn't.
You can do all of the for $75-80 instead of $300+ for a new distributor. I carry a pick-up and reluctor wheel in my box.
osen007 07-14-2011 01:11 PM
The Distributor is a 8560 I checked it at lunch and under the weights its all rusty like. So I will clean and replace pick-up and reluctor wheel.
RT930turbo 07-18-2011 09:32 AM
Have a chance to get it out this weekend? How'd it do?
osen007 07-18-2011 12:12 PM
I got tied up went the Detroit tigers game and a batchlor party after Saturday. Didnt get off couch sunday. I would of been better off stayng home. Ill keep you posted.
RT930turbo 07-18-2011 01:05 PM
:lolhit: Soulds like a good time then!
