Cleaning White Interior
Who uses what to clean their interior.. White vinyl with grease on top of rear seat climbing out of engine room after oil changes and tune up's........
I use some magic eraser on the grease spots and it works great getting it all out.
Originally Posted by lowblue320
(Post 3467062)
I use the orange pumus hand soap with a soft bristle brush and then wipe with a damp rag. It takes the grease out of the creases in the vinyl .
Rick G. |
go to the dollar store and get yourself a bottle of "awsome" and a magic eraser... works awsome!!
Hopefully this link works. Best stuff I've found. This is actually what Cigarette uses at the factory for interior cleaning.
http://stores.ztuffstuff.com/StoreFront.bok |
Trs Props
Any body know anything about trs solid hub cleavers?
Originally Posted by scarab123
(Post 3468291)
Spray Nine and if needed, Magic Eraser.
+1 on the "totally awesome" from the dollar store and a magic eraser. make sure you go back over it with a protectant. i use "303 protectant" works great!
Becarefull what you use the magic eraser on.What ever is in them eats the threads in stiching.
I use stuff called Roll- Off ,works great
I feel your pain, it seems nearly impossible to keep an all white interior clean.
I hit the heavier stuff with diluted Simple Green (~50:50 or less) and it takes it right up with a single wipe or two. I keep a Magic Eraser or two on board, and they work well, but they dont last all that long or work quite as well as Simple Green and clean hand towel IMO. BTW, I buy the Simple Green by the gallon and it's fairly cheap and last a long time. I use it for spaying down the engine compartment (diluted 50:50, then hose it out), it does a great job removing the oil residue that seems to blow out my breathers every time I run the boat. |
I use Clorox Cleanup and Majic Eraser together. Like others have said, stay away from the threads! Then be sure to coat with the 303 protectant.
I had a plastic bag from Frostys on the front seat on the ride back from PIB. The lettering melted to the seat and it's not coming off. Any suggestions....? |
Originally Posted by frickstyle
(Post 3468701)
Agree by far the best magic eraser
Does Magic Eraser have bleach in it?
Originally Posted by ActiveFun
(Post 3469078)
Mineral spirits is probably one of the best products to clean vinyl with. Do some internet research, you'll be suprised. and the good thing is you'll know exactly what the product is that you're using. Who knows what's in all those miracle cleaners and what it does to your vinyl.
The guy that redid all my vinyl is a classic car upolsterer and that's all he has ever used. ed |
if you use a micro fiber towel and your favorite cleaner,,,it cleans better than a cotton towel,,,just something that,s not as harsh as magic eraser:drink:
| All times are GMT -5. The time now is 11:11 PM. |
