-   -   Engine still won't fire up. (https://www.offshoreonly.com/forums/cigarette/261622-engine-still-wont-fire-up.html)
Carlo 09-03-2011 01:34 PM
Further to my thread "Ignition Problem", thought we had found the problem and replaced the ignition sensor but still no luck! The coil,distributor cap and amplifier are all ok, the only odd thing is that the gaffrig tacho on the good engine sits on zero when switched off but the tacho on the bad engine sits about 1" below zero. Does this point to another problem?
Holy Smokes 09-04-2011 06:16 PM
We really need more info to help diagnose what it could be0. I would suggest checking ground wires. The tach's should "jump" when the ignition is turned on. As long as they zero-out when the ignition is turned on they're OK.
Also, check the actual ignitions as well.
Carlo 09-05-2011 12:34 PM
Problem Solved
Thanks for your suggestions. Discovered that the culprit is the rev limiter (Overspeed Assembly) - the little black box that hides behind the module marked Thunderbolt IV. Managed to find a new one here in the UK so hope to get to sea in a day or so. Have to say that I could not find this on any of the wiring diagrams for my set up or no mention in the workshop manual.
Holy Smokes 09-05-2011 09:26 PM
Glad you found it!
