-   -   1995 TG Bilge & Drain (https://www.offshoreonly.com/forums/cigarette/278975-1995-tg-bilge-drain.html)
36Envision 06-19-2012 05:58 PM
Two questions - How much water should collect in the bilge? Right now say two gallons seems to collect when in the water, pretty quickly. Not enough for bilge pump to kick on. It also has a slight sour odor. I drain bilge, then wet Vac the remaining water out when done for the weekend.
Second - where does the cooler in the Cuddy cabin drain? Does anyone use this often? Good or bad? Wife wants to use it....I am just not sure. Thanks!!
seafordguy 06-19-2012 08:32 PM
NO water should come in the bilge if everything is working right.
Common places for water to come in in the nature you are talking about would be:
Swivel Seals in the Transom Assembly
Turn Down Exhaust Leaks (my cmi silent choice seals leak about once a year. I hate them)
U-Joint Bellows Leak
Shift Cable Bellows Leak
Toilet Leak
Fresh Water Tank Leak
Cooler drains into the bilge. Personally - I use it as a liquor storage place. We used to use it for ice/etc, but it just wasn't that pleasant, and I decided using a regular cooler that I can take out of the boat and clean was much nicer.
cafe man 06-19-2012 09:07 PM
I also have a question about this topic: at the deck on the Cafés are 2 holes for drain. Wehre goes this water? Also in bilge?
36Envision 06-19-2012 09:55 PM
I believe these holes are for water to drain that may leak under the two deck hatches.
36Envision 06-19-2012 10:05 PM
Toilet Leak
Fresh Water Tank Leak.
We don't use the toilet or freshwater so I don't believe that is it. I'll have to look this weekend when it is in the water. Thanks.
Zero Patience 06-20-2012 07:51 PM
Most cigs have a diaphram pump on the firewall with the pick up close to the drain plugs, it pumps out most all water from the bilge. The three we have here all have one.
