procedure for pulling motors in 28ss?
I was wondering how to get the motors out of my 85 28ss? The rear deck overlaps the engines so they can not be pulled straight out. Do I have to pull the drives ,then the trannys, then slide the motors back and pull them out?
28" engine removal expert
The most knowledgeable person I know, who has rigged, raced, re-rigged, is Andy Bloom. He works in Mentor, OH at a shop called "Victory". If you want help, he is a great guy: [email protected] or call him at 440-975-0010
Good Luck |
just did mine .if you have trs . remove drive losen 6 bolts in tailshaft undo wiring / exhaust . unbolt engine mounts . pull trans with engine. tip, just turn engine a litle bit and will go straight up.
| All times are GMT -5. The time now is 11:27 PM. |
