-   -   Hot for Teacher (https://www.offshoreonly.com/forums/cigarette/287736-hot-teacher.html)
Quinlan 11-14-2012 07:32 AM
Hot for Teacher
Anybody got a couple shots of the scoops? Or any others with raised pad.
Thinking bout doing chillers and looking for ideas on what the sun pad will end up like.
tim mccray 11-14-2012 11:57 AM
Are you asking about the "Hot For Teacher" boat scoops? If so I'll see if I have a pic or I can see if Tom has something to post or send you. I believe it's a standard hatch, not raised with scoops glassed in, no inserts, and clears everything well.
OldSchool 11-14-2012 12:12 PM
3 Attachment(s)
Here you go. These are from September at the Cigarette Rendezvous in Destin...
HUSTLEthis 11-14-2012 12:44 PM
Originally Posted by OldSchool (Post 3814923)
Here you go. These are from September at the Cigarette Rendesvous in Destin...
Thanks Craig, I have a few more (on the home computer) if
you need some more.....It's the raised hatch with the scoops
added....
VortechSS 11-14-2012 02:23 PM
Dayum! New drives, new scoops, new chillers, new pulleys... Goin big next year! :Score-101010:
BTW Tom, the HFT crew & boat looked good at Gilberts on Thursday.. Saw you getting fuel there and then heard later on that someone had possibly pumped some bad gas outta there... hopefully it wasnt any of your group!
frickstyle 11-14-2012 04:30 PM
added....
Are the scoops for clearance? What is your setup? 10-71s with chillers?
HUSTLEthis 11-14-2012 04:58 PM
Thanks, the gas we got was good.... It was a great run
HUSTLEthis 11-14-2012 05:00 PM
yup, needed for clearance....14-71's w/coolers
carter38 11-14-2012 05:35 PM
8 Attachment(s)
Bada$$! Scoops Rock!
Quinlan 11-14-2012 07:43 PM
Thanks guys.
Smitty 11-14-2012 08:26 PM
Q
Have you looked into Whipple chillers ?? I believe they are much lower than other options and you might not need to do scoops.
frickstyle 11-16-2012 06:55 AM
Ha, 14-71s, that's awesome. What kind of boost/octane do you run? I'm getting a little nervous that mine won't clear now. anyone have a measurement from engine plates to underside of the mid 2000s raised hatch (inside)? The hatch similar to HFT without scoops, factory style....
J-Bonz 11-16-2012 08:32 PM
1 Attachment(s)
Here's my buddy's boat.... He is running the Merc 575's
HUSTLEthis 11-16-2012 11:34 PM
1 Attachment(s)
about 5lbs, since the boats in Fl for the winter...
I run the highest octane available...90-93
