How to put a Notch in a Flat Deck >
Old 04-07-2013 | 10:55 PM
  #91
scippy's Avatar
Nice clean work Rick!......Does Kevlar pose any difficulty say from a 1708?.....I heard it's harder to cut.
scippy is offline
Old 04-08-2013 | 06:12 AM
  #92
Thanks Scippy . Yes it does , in fact I had to buy scissors specific for cutting Kevlar .
RG.
Rick G is offline
Old 05-06-2013 | 08:43 AM
  #93
Well the heavy lifting is over . I have the notch roughed in and structurally complete . Now begins the finishing and final gelcoat application . End of the week it goes to my buddies marina where we are going to replace the transom ( need an extra pair of hands ) . Then we rerigg.
Here are a few shots of the roughed in notch.
RG.
Rick G is offline
Old 05-06-2013 | 08:45 AM
  #94
cougarman's Avatar
RG.
Rick,
Your pictures seem to be invisible?
Jon
cougarman is offline
Old 05-06-2013 | 08:57 AM
  #95
Sorry its Monday.
Attached Thumbnails How to put a Notch in a Flat Deck-img-20130505-00204.jpg   How to put a Notch in a Flat Deck-img-20130505-00205.jpg   How to put a Notch in a Flat Deck-img-20130505-00206.jpg
Rick G is offline
Old 05-06-2013 | 11:09 AM
  #96
cougarman's Avatar
Rick,
Looking Good, are you adding and Stringer Gussets?
Adds tons of transome support...
Jon
Old 05-06-2013 | 11:24 AM
  #97
Absolutely . I need to redo the transom , that will happen the end of this week and then I can complete the stringer reinforcement.
RG.
Rick G is offline
Old 05-06-2013 | 11:48 AM
  #98
glassdave's Avatar
Neno the mind boggler
Originally Posted by Orionsilverboat
Your going to be very suprised how hard it is, cutting the hull like that is a big mistake, it will never be the same structurally, good luck
Just saw this thread
Nope osb in theory your repair will be as strong or stronger then what was there if done properly and by the looks of it it is certainly being done properly
I've cut entire boats nearly in half, the mean green race machine has two years and twenty plus races on this repair without even the slightest stress crack. This was one of the most advanced repairs i have ever done. Some day i will do a thread on it
Not try'in to highjack, just had to jump in carry on man nice work!
Attached Thumbnails How to put a Notch in a Flat Deck-2011-02-15_16-14-58_740.jpg   How to put a Notch in a Flat Deck-2011-02-15_19-27-19_579.jpg   How to put a Notch in a Flat Deck-2011-02-16_12-05-43_380.jpg
How to put a Notch in a Flat Deck-2011-02-16_12-23-57_514.jpg   How to put a Notch in a Flat Deck-2011-02-16_15-39-01_429.jpg   How to put a Notch in a Flat Deck-2011-02-17_13-00-57_985.jpg
08 OPA High Points Champion
glassdave is offline
Old 05-06-2013 | 12:48 PM
  #99
nice work Dave. Where did you get the piece to graft in there?
kvogt is offline
Old 05-06-2013 | 01:25 PM
  #100
glassdave's Avatar
before i chopped the nose off we pulled the whole sponson back over with a back hoe then i re worked the surface with a ton of bondo and drywall screws and pulled a mold. The inner core was blown as well as the bulkheads but it was still kinda the original shape. I thought about pulling a mold off another (Shawn in Windsor graciously offered up his) but in the end it was better to rough this one back into shape and pull a mold here. The way i managed the surface and the core layup made fitting the actual part on the boat a fifteen minute process. It would have been a tougher time had i pulled it from another boat. I will do a thread someday . . . . if a ever get some spare time
Rick, will this notch require you to raise the X dim?
again Rick sorry for the slight detour
Attached Thumbnails How to put a Notch in a Flat Deck-2011-01-04_19-12-38_593.jpg   How to put a Notch in a Flat Deck-2011-01-12_18-44-47_160.jpg   How to put a Notch in a Flat Deck-2011-02-10_17-13-52_232.jpg
