factory 1999 TG dash with Gaffrig gauges and all bezels
complete dash for sale
http://www.offshoreonly.com/forums/s...sh-gauges.html |
additional information with sizes
(x2)*3 3/8 ELECTRIC TACHOMETER 0-8000 RPM BLACK CF* (x2)*2*1/16*" ELECTRIC FUEL LEVEL 240-33 OHMS-BLACK/ CF 270 DEGREE SWEEP (x2)*2*1/16*" ELECTRIC VOLTMETER 10-18 VOLT BLACK/ CF 270 DEGREE SWEEP (x2)*2*1/16*" MECHANICAL BOOST 0-35 PSI BLACK / CF 2 72.00 144.00T (x2)*2*1/16*" MECHANICAL WATER PRESS. 0-35 PSI BLACK / CF (x2)*2*1/16*" ELECTRIC WATER TEMP. 100-280F BLACK/ CF 270 DEGREE SWEEP* (x2)*2*1/16*" ELECTRIC OIL TEMP. 100-320F BLACK/ CF 270 DEGREE SWEEP (x2)*2*1/16*" ELECTRIC OIL PRESSURE 0-100 PSI BLACK/ CF 270 DEGREE SWEEP* (x2)*2*1/16*" Mechanical Fuel Pressure Black/ CF 0-15 Psi* (x2)*FUE PRESSURE*SENDERD*0-15 PSI (x2) WATER TEMPERATURESENDER*3/8 INCH (x2)OIL PRESSURE*SNEDER*0-100 PSI (x2)HIGH WATER TEMPERATURESENDER*3/8 INCHXM500 (x2)*Program Box # 78700420* (x2) 0-100 Gph Cruisemaster Meterhead Black/ CFadditional information with sizes (x2)*3 3/8 ELECTRIC TACHOMETER 0-8000 RPM BLACK CF* (x2)*2*1/16*" ELECTRIC FUEL LEVEL 240-33 OHMS-BLACK/ CF 270 DEGREE SWEEP (x2)*2*1/16*" ELECTRIC VOLTMETER 10-18 VOLT BLACK/ CF 270 DEGREE SWEEP (x2)*2*1/16*" MECHANICAL BOOST 0-35 PSI BLACK / CF 2 72.00 144.00T (x2)*2*1/16*" MECHANICAL WATER PRESS. 0-35 PSI BLACK / CF (x2)*2*1/16*" ELECTRIC WATER TEMP. 100-280F BLACK/ CF 270 DEGREE SWEEP* (x2)*2*1/16*" ELECTRIC OIL TEMP. 100-320F BLACK/ CF 270 DEGREE SWEEP (x2)*2*1/16*" ELECTRIC OIL PRESSURE 0-100 PSI BLACK/ CF 270 DEGREE SWEEP* (x2)*2*1/16*" Mechanical Fuel Pressure Black/ CF 0-15 Psi* (x2)*FUE PRESSURE*SENDERD*0-15 PSI (x2) WATER TEMPERATURESENDER*3/8 INCH (x2)OIL PRESSURE*SNEDER*0-100 PSI (x2)HIGH WATER TEMPERATURESENDER*3/8 INCHXM500 (x2)*Program Box # 78700420* (x2) 0-100 Gph Cruisemaster Meterhead Black/ CF |
| All times are GMT -5. The time now is 12:29 PM. |
