-   -   Freshwater tank (https://www.offshoreonly.com/forums/cigarette/297955-freshwater-tank.html)
88bullet 06-10-2013 10:19 PM
Freshwater tank
Anyone ever replace a freshwater tank in a older top gun. Filled mine today to test everything out and it appears to be leaking. How much of a b!tch is it to get it out?
RWS Cigarette 06-10-2013 10:29 PM
And the FUN begins!!!
Sydwayz 06-10-2013 10:58 PM
Maybe Rotozip the top off of it and put a bladder inside old tank?
Are you sure it is leaking, or did it overflow out the vent? I've seen the latter happen.
88bullet 06-10-2013 11:15 PM
I filled it til it came out the vent on the side of the boat and then noticed a lot of water coming out my drain hole in the back of the boat. Looked in the trap door and seems water is running out from under the tank. Ugh... It holds some. It's aluminum I wouldn't think it would have cracked. Might break out the bore scope and see what I can see.
88bullet 06-10-2013 11:16 PM
Is there a vent on the tank itself? I thought just the vent hose up near the rub rail
ICDEDPPL 06-11-2013 07:20 PM
Fresh water is for pussies! I`m filling mine with Vodka!
88bullet 06-11-2013 07:47 PM
it would get expensive if vodka leaked out too!
cigrocket 06-12-2013 07:35 AM
Lot more expensive! lol.
See you guys at A-Bay this weekend
