38 Top Gun Standoff Boxes or not???
I have a 1990 TG Notched transom TRS Boat converting to Bravos, should I put 12" Standoff Boxes?
Does it better the Ride, Faster? Frank |
Forget the Bravos, keep the TRS.
couldent agree more .keep the trs ,if your worried buy 1 spare right drive and if you break a left swap the prop shaft .
ZP knows where a good spare set of TRS drives can be had cheap ....I think...
did you add 6s to your boat??
Originally Posted by Zero Patience
(Post 3943700)
Originally Posted by cfischer
(Post 3943799)
did you add 6's to your boat?
Originally Posted by MrSneakAttack
(Post 3943801)
yes he did. he has a thread on it on another site. it was a very cool project
Bought boat without power nor drives, have all the Bravo gimbles, Drives etc.
Just wanted to know if they ride better with or without Boxes. |
Typically the extension boxes puts the props back farther in cleaner water and make the boat more capable because it lengthens the overall running area. Not sure how the balance will be since the boat was designed around transmissions and drives. Now you are adding bravos and boxes. Good thing is you will be able to play with the x dimensions and boxes. Plus today more prop choices also help in boat capabilities..
| All times are GMT -5. The time now is 09:39 AM. |
