Slippery swim platform
What do you guys do for anti slip? This thing is like a slip and slide when wet, I`m horrified that someone might slip off right on top of the cleavers. :eek:
http://33outlaw.zenfolio.com/img/s8/...58888622-4.jpg If Hydroturf made a perfect fitting kit that would be sweet. |
x2
Mine is the same after being repainted. What's out there for options? |
Send it to Vincent this winter. He painted mine up then painted on Non skid. Works like a dream
see if there is a non-skid additive you can put in a clear coat. Then tape off the top areas and spray with non-skid clear.
I wonder what SEA deck would look like on it .. they send out a template kit for a custom look.. Short Bus you ever use that tape? Wonder how it holds up wet
Originally Posted by Quinlan
(Post 3951754)
Originally Posted by ICDEDPPL
(Post 3951841)
The draw back is sitting on it seemed to bother the wife a little, but I told her it is better than a busted face :D |
Krylon makes a spray bomb clear non-skid. I've used it in a few spot in my engine compartment and it works well.
Dan, can you get a sheet of hydroturf, and cut it out from the bottom side of platform?
| All times are GMT -5. The time now is 10:01 PM. |
