Air Conditioning
Just curious as to how difficult (or expensive for someone to do it) it would be to add air to a 38 TG that didn't have it. How does that work? I see the vents under the v-berth in pics, but is there anything else that gets put in elsewhere? I've heard that 388 Hustlers come pre-wired for air and it's $2500 to add, but are there any vents and ducts anywhere that the air comes out, or just in that one spot?
Being a Fountain owner considering a Cig, I'd like that A/C so I can still wear my turtleneck, and if it gets too hot, my gold chains stick to my neck :D:D:D:D:D |
I put air in my Cig it was about $1200 or so I bought it from artic air in Florida. It comes as a complete kit. It took a good day to put in.
Originally Posted by MR.CIG
(Post 339915)
That seems to be a name that three comapnies have in Florida, and then a few have "arCtic air" as well. Thanks! JT |
We put in an Ocean Breeze (www.OceanBreezeac.com) system in , 12000 btu's with heat, the whole system was right around $1000, it took 1 full day to install.
Originally Posted by Panic Button
(Post 2247767)
Originally Posted by Sea-Dated
(Post 2247851)
I am wanting to put air in my Cafe'. How hard was the install? Do you have any pics of the finished product or pics of the install process? I am curious to know how you did it and where you put the water pick-ups.
Water pickup and pump is next to the raw water pickup for the head. Discharge for the rater is right above the sink drain for the head sink. I mounted the AC unit in the V-Berth with the 2 air ducts running up the dividers where the cabin fans are. Hardest part was getting myself to drill the hull. To run the ducts the stringers already had 2 3.5" holes and a 110v cable to the V-berth and to the breaker panel. I'll post some pictures later today for you. |
Don't forget the pics...I too would like to see your work! ;)
(Post 2247851)
2 Attachment(s)
Originally Posted by US1 Fountain
(Post 2253277)
My slip neighbor installed a Mermaid 6500 Btu unit in his '91 Cafe this winter. Works great! He used the existing thru hull pickup from the head 'I think' as the AC pickup since he doesn't use the head and the sink drain thru hull was used for the outlet. No new holes drilled. PUmp and strainer are mounted in he side storage seat compartment where the thru hulls are accessed from. Give it some time and maybe he'll chime in here.
I jhave to uncover everything to get in the boat for photos, I'll try to do that today if it doesn't rain again. Here are the pick up and discharge locations. |
| All times are GMT -5. The time now is 03:13 PM. |
