Top gun hatch arm!
2 Attachment(s)
Here is the first hatch arm. What do you guys think?
[ATTACH=CONFIG]520267[/ATTACH][ATTACH=CONFIG]520268[/ATTACH] |
Very cool, great work.
Those should sell well.
The cig oval can be used vs the script too. What address am i shipping yours to?
1 Attachment(s)
I would like one. If I come up with an alternative end design for the roller bearing setup, can you make it?
Also posted this in the other thread. Check out how the lifting point / bearing housing attaches to the rod (upper right in pic), pretty simple design. You can just make the end solid with a thru hole, and I can make the bearing housing and rod assembly here, or you could design as a package? [ATTACH=CONFIG]520279[/ATTACH] Can you PM me with a quote for the "as-is" that you posted? |
nice work!
Originally Posted by frickstyle
(Post 4089584)
1 Attachment(s)
Here is what it looks like installed on the boat
[ATTACH=CONFIG]520355[/ATTACH] |
Anyone know what the difference between a Top Gun hatch arm and a Bullet hatch arm is? In other words, are they the same or different?
Buck |
your pm box is full buck
Originally Posted by 88bullet
(Post 4090455)
Same.
Those look great.
Originally Posted by carter38
(Post 4091085)
Same.
| All times are GMT -5. The time now is 10:07 AM. |
