-   -   38 Top Gun (https://www.offshoreonly.com/forums/cigarette/312965-38-top-gun.html)
Braxton88 05-28-2014 11:29 PM
38 Top Gun
I'm thinking of purchasing a 38 Top Gun , it has 700hp engines with Konrad drives turning 30's , motors are suppose to be capable of turning low six's without hurting them. What kinda top speed should I expect ?
Zero Patience 05-29-2014 05:04 AM
2 foot chop, 1/2 fuel, 78-80
kreed 05-29-2014 06:24 AM
If they are spinning 30's at 6 grand, I would bet they are over 700 HP...... I had a 700 HP Gun that spun 28's right at 5500 RPM at about 80 MPH
Braxton88 05-29-2014 10:53 AM
He told me that at 4800 it was hitting 80, he said he didn't want to run them higher cause it only had 20 hours on them. The motors we're suppose to be 715 before the rebuild , he them went to a larger cam and aluminum heads , but did not dyno the engines . He suspects 750 hp now and engines capable of turning in the low sixs ???
These are not blower motors and are single 1050 carbs. The boat is gorgeous and completely redone but I'm really wanting a hundred MPH boat so I'm really on the fence ???
88bullet 05-29-2014 11:01 AM
well i will tell you what. unless you have driven the boat or seen it run those numbers in person on GPS i think im gonna have to declare b/s. i have 750's and run low 80's in a kevlar hull. my buddy has over 1000hp in his konrad boat and it barely hits 100. better get a ride in it and see what it really does. the motors might be good to the 6k+ rpm range but what will they really spin to in the boat with the props he has on it?
cigrocket 05-29-2014 11:21 AM
Runaway, Things don't add up at all if this is his story. Engines with 20 hours are broken in. Should be ready to Spin the RPM's if they will. 6000rpm 750HP. Wouldn't make a move unless I was on the boat, and running it. We are talking about a straight bottom gun, correct????
Sick Stinger 05-29-2014 11:45 AM
4800 80 MPH or KILO numbers are not correct, 1.5 drive or 1.36? Bravo or speedy boat? Pics info link to boat?
Sick Stinger 05-29-2014 11:47 AM
In sorry just saw the Konrad thing my fault, great drive takes a little more turn turn them but they are shorter and stronger then TRS so good upgrade alrwady done. Numbers are not there though
kreed 05-29-2014 11:53 AM
Personal message Cigrocket a few posts up........he has an awesome TG for sale too....maybe he will post a few pics!
frickstyle 05-29-2014 11:53 AM
Go run the thing, then decide.
Braxton88 05-29-2014 11:58 AM
Yes , 93 model , he said he could add 871 s with dual 1060's for about twenty grand
It's running 91/2 compression , will that work with blowers
And how much HP / speed could I honestly expect .
The drives are Konrad and supposedly rated at 800 HP
I'm open to another boat if someone know of something
I've got about a 80/100k budget ( poor boy ) lol
I'm wanting something towable ie poker runs
Rbesola 05-29-2014 02:16 PM
im not sure id put any more air to a 9.5:1 engine myself but im sure someone will chime in on that. also food for thought, i have around 800ish hp maybe 850 and only seeing 90. 100 is going to take some serious cash unless you find a step boat
88bullet 05-29-2014 02:33 PM
cig rocket sold his T/G already.
sent ya a pm
bigfarmer 05-29-2014 06:14 PM
http://www.offshoreonly.com/classifi...o56185-en.html
Here's your answer right here.
cigrocket 05-29-2014 07:21 PM
Originally Posted by bigfarmer (Post 4129684)
+1. Sounds like this is what he wants!
payuppsucker 05-30-2014 08:48 PM
It don't get much better than that, not for under 100.
jaysflatdeck 05-30-2014 10:28 PM
I'm buddy's with bigfarmer his boat is clean & someone would get a nice running package for there money
jbraun2828 05-31-2014 07:05 AM
That thing is bad azz
