-   -   Top Gun 38 Fuel tank Help (https://www.offshoreonly.com/forums/cigarette/315874-top-gun-38-fuel-tank-help.html)
airshares 07-25-2014 05:47 PM
Trying to get an understanding of my Fuel situation on my 38. Its all new to me and I've never used the boat yet. I'm getting ready to put it in the water tomorrow and just needing some help to understand the fuel system on the Top Gun.
Its a 1999 Top Gun 38 with 2 fuel tanks as it has 2 fuel gauges and I THINK 2 filler caps. Here are my questions:
Does one filler fill both tanks and do the motors run off both tanks or is there is a selector switch to use 1 tank or the other??
Thanks for any help on this. Just trying to understand the systems before I use.
Bryan
smokin' gun 07-25-2014 06:17 PM
2 tanks 2 fills each motor runs on each tank ..you put 50 gals in 1 tank do the same on the other tank ..however you will find 1 tank always needs a little more than the other ...their is 4 ball valves at the back of tank ..you can run both motors off one tank ..you should have tags on the handles telling you how to do it ..when you run both motors off one tank they say not to go over 3500 rpm
endeavor1 07-25-2014 06:18 PM
1 filler for each tank. 1 tank for each motor. You may have crossover valves under the inspection covers in the bilge that will let you pull from either tank to either motor. That's how my 01 TS was if I remember right
ICDEDPPL 07-25-2014 08:56 PM
Not enough vent?
FIXX 07-26-2014 01:49 AM
Originally Posted by ICDEDPPL (Post 4160064)
Not enough vent?
Fuel pick's to close to eachother..
ICDEDPPL 07-27-2014 09:11 PM
interesting.. Ive had it to 5200 on one tank no issues
Boater0979 07-28-2014 12:30 PM
I've run above 3500 on one tank but soon after engines starved for fuel.
