-   -   Top Gun Compass (https://www.offshoreonly.com/forums/cigarette/317562-top-gun-compass.html)
twinscrews 09-03-2014 07:50 AM
Top Gun Compass
The compass on my boat has gone bad, (04) and I would like to put something else in it's place. Has anyone ever taken there's out and replaced with something other than a compass, if so, what and pics would be nice. Not a real need for a compass with GPS. Thanks in advance
36Envision 09-03-2014 08:17 AM
I've seen some where it is removed & a plate is machined to fit over the hole with the Cigarette script or logo on the plate. That is what I'd try to do if I removed mine.
smokin' gun 09-03-2014 08:32 AM
Compass is an easy fix .. Most of them the diaphragm goes bad
Parts can be bought locally and refill it with mineral spirits
plumbers crack 09-03-2014 09:45 AM
My gps is not dash mounted. I was going to cut the hump out and get ,ew dash plate and flush mount my gps there. My compass is non functional, plus have another at nav station.
glassdave 09-03-2014 10:38 AM
2 Attachment(s)
i make these caps to update the dash. Eliminates compass and allows a better layout. Cut off the compass riser, remove the factory aluminum panels and it screws right on over the existing dash. :cool:
MrCIG 09-03-2014 01:46 PM
You want to use Mineral oil not spirits
Mark
twinscrews 09-03-2014 02:03 PM
Not sure what aluminum panels you are talking about, and looks as if you did glass work to make it look finished. That looks a whole lot better though, very nice.
Rick G 09-03-2014 02:13 PM
Bear in mind that in Canada the rules require that boats over a certain length require a compass , you may want to check your state or federal regulations to be sure you are legal without a compass . GPS only work if you have power .
Just a thought .
RG.
jmackin 09-03-2014 02:35 PM
I have an electronic compass in mine. Looks and works really good. use it al the time
glassdave 09-03-2014 04:17 PM
1 Attachment(s)
the gauge panels, there should be two screw in panels that hold all the gauges. This cap covers all of that with no glasswork but you do need to do some wiring and stuff. Heres the raw panel
plumbers crack 09-03-2014 04:27 PM
my dash now
1 Attachment(s)
[ATTACH=CONFIG]528731[/ATTACH]
plumbers crack 09-03-2014 04:29 PM
I have a few more gauges than most LOL
plumbers crack 09-03-2014 04:31 PM
Did you make your bracket for the windshield and the plexi? , or did you buy the bracket from Cig ?
glassdave 09-03-2014 06:43 PM
if you are referring to the one in my pic i make both the plexi (acrylic actually) and the brackets. I've got like six of the of the "plexis" laying around brand new un drilled, last time i got my pattern out i knocked off a whole sheet lol. The brackets werent to bad i made them out of stainless plate and break them to the angle needed then drill and tap. They are plenty rigid, thinking about listing the blanks in the swap to get rid of a few of them. Man i tell ya what ya move your shop and ya realize how much stuff ya have lol
smokin' gun 09-03-2014 07:11 PM
Mark
Nope sorry they sent me a new diaphragm and a can of
Odor less mineral spirits of witch they told me to put in fridge
To get cold so I would have no bubbles. When I filled it
Maybe they don't know what there doing ??
Either way it's been like that over a year and works fine
plumbers crack 09-03-2014 08:05 PM
I guess you can put in the brake but, then its a slight radius for the deck correct? So a compound bend so to speak
glassdave 09-03-2014 09:55 PM
actually I did seven small one and a half inch wide stainless brackets. Truth be told I got a whole kit from Cig a few years ago and making these brackets was easier then wrestling with the welded one I got it the kit. Because of the compound angle of the deck the individual ones I made became pretty rigid when installed, every bit as much as the factory one.
I was thinking about even making a mold for composite bracket. you'd be surprised how strong an epoxy/s-glass bracket would be :cool:
carter38 09-04-2014 09:10 AM
That looks awesome Dave very nice upgrade.
plumbers crack 09-04-2014 01:46 PM
I was thinking the same thing Dave, multiple brakets. BTW the acrylic/plexi is rough cut? or is it sanded and ready to go? Im in if its ready to rock.
Tom A. 09-04-2014 02:44 PM
Quick easy replacement and update:
https://www.donzidirect.com/clearanc...hite-1000.html
BTW, those panels you made Dave are an awesome upgrade!
jmackin 09-04-2014 03:19 PM
This is what i have and it is awesome. Much quicker and easier.
glassdave 09-04-2014 03:23 PM
1 Attachment(s)
the edge is finished all the way around but the bottom may require a bit of fitting to your boat, just depends how snug ya want it. I put a general bevel on the bottom edge but all the ones i have done needed to be fit per boat and per brackets, same with the holes. Its somewhat "advanced do-it-yourselfer" but thats what most boat owners are here anyways :D :cool:
plumbers crack 09-04-2014 09:13 PM
I heard it should be shimmed so it doesnt squeak do you put a small amount of silicone on the bottom ? I guess the rain would sit in there if you did so maybe every couple inches?
DirtyMoney 09-04-2014 10:48 PM
1 Attachment(s)
I put in a cup holder
mrpickett357 09-05-2014 10:34 PM
1 Attachment(s)
[ATTACH=CONFIG]528836[/ATTACH]
Before
mrpickett357 09-05-2014 10:43 PM
2 Attachment(s)
[ATTACH=CONFIG]528837[/ATTACH][ATTACH=CONFIG]528838[/ATTACH]
After
plumbers crack 09-06-2014 03:16 PM
After
Nice job, did you buy or make the gps bezel
twinscrews 09-07-2014 05:57 AM
After
Very nice
mrpickett357 09-13-2014 08:24 PM
2 Attachment(s)
During the restoration of Lock & Load we moved the compass to the port side dash and fabricated the GPS as a built in part of the new helm. [ATTACH=CONFIG]529514[/ATTACH][ATTACH=CONFIG]529515[/ATTACH] Zero Patience built the bracket in aluminum using cardboard mock up made to get the angle right.
Flamingo 42 09-13-2014 11:31 PM
1 Attachment(s)
My compass doesn't work and is dash mounted, I checked with Richie and it's obsolete with no replacement available...any ideas
l_sotero 09-14-2014 05:36 PM
1 Attachment(s)
[ATTACH=CONFIG]529569[/ATTACH]
Thank to Dave....
BTW I love this compass it works great!!!
