-   -   Pirrelli Floor (https://www.offshoreonly.com/forums/cigarette/325857-pirrelli-floor.html)
jmackin 05-04-2015 02:52 PM
Pirrelli Floor
Any way to clean this stuff? Looks like a dark brown stain from the carpet backing. Not sure but in good shape otherwise.
jmackin 05-04-2015 02:57 PM
Actually its this stuff.
http://www.lonseal.com/show_product/LONWAVE%20MIRAGE
sonicss42 05-04-2015 04:00 PM
Had black Pirelli floor in my Sonic and used to spray down with foaming tire cleaner/shine from the likes of AmorAll. Worked pretty good but also makes it pretty slick. Be careful.
offshoredrillin 05-04-2015 04:48 PM
i use either simple green or 303 as well as a steamer, it blows the dirt right out of the cracks.
jmackin 05-04-2015 05:56 PM
Bleach, scrubbin bubbles, de greasers, etc doesnt touch wutever is staining this floor. its not a dirt or mold.
TWIN-SPINS 05-04-2015 08:09 PM
Cleaned ours with shower cleaner scrub brush,and wiped with dry rag,,,I think your right about the carpet backing causing the discolor
Griff 05-05-2015 01:50 AM
I have a couple small brown stains on mine. Nothing will remove them.
pm203 05-05-2015 07:39 PM
When you have your carpet made, you need to use vinyl as a backing. This will prevent the staining. Also, I noticed a lot of Florida boats flooring yellows prematurely due to the sun.
jmackin 05-05-2015 08:59 PM
Yes, talked to Lonseal today. That is what they said, no rubber backing, vinyl only. Nothing will remove it. Have to replace. Looks like where the sun hit it, under seats are much better than the open areas.
