-   -   90 TG What type fluid? (https://www.offshoreonly.com/forums/cigarette/328915-90-tg-what-type-fluid.html)
jsbrowni 07-26-2015 07:28 AM
1 Attachment(s)
On a 90 TG, what type fluid goes in oil reservoir on TRS transom assemblies?
[ATTACH=CONFIG]543514[/ATTACH]
smokin' gun 07-26-2015 07:49 AM
hp gear oil that spot takes the place of a gear lube bottle
jsbrowni 07-26-2015 08:22 AM
OK. I noticed the lower unit only has a lower screw for draining oil but no upper screw to for knowing the unit is full. Is there a fill procedure; i am guessing it will take some time for the lube in resivoir to work its way down before the dip stick is accurate?
Thanks for your feedback,
Shawn
Zero Patience 07-26-2015 02:55 PM
Shawn
There is also a vent plug in the drive, port side, just below the input shaft level.
jsbrowni 07-26-2015 08:30 PM
Oh, I see it does have a top plug in the upper case; I was thinking of my old Johnson outboards that had the upper plug on the lower gear case. It took 3 quarts in case and 1 in reservoir. Does anyone know if the drain screws are supposed to have gaskets or an o-ring? neither was found when removed.
Craney 07-26-2015 10:21 PM
It should have a o-ring look inside they stick sometimes.
Zero Patience 07-27-2015 08:29 PM
Gaskets, standard merc, flat fiber washer type
