-   -   Cig full of water - help! (https://www.offshoreonly.com/forums/cigarette/333472-cig-full-water-help.html)
way2fast 01-02-2016 08:51 PM
I have left my cig mistress on a mooring bouy for 2 days and came back and the step into the cabin down from the cockpit is filled with a deep pool of water.
I turned on my bilge pumps to pump out but nothing came and looked under my engine room which was dry. it is so irritating and I cant seem to get it out. as the pumps only pump out water from the engine compartment. and it wont drain from the front into the back of the boat
can anyone shed some light.
Craney 01-03-2016 04:53 AM
Sounds like you have a clogged drain line. If you have a air compresser try blowing out the drain holes.
rak rua 01-03-2016 05:36 AM
Water can only get in via the cockpit or an inlet/outlet below sea level. Do you have any drains for a sink or maybe a water inlet in the hull with a sea cock? I had water come into the cabin of a boat many years ago while we were anchored. It was an inlet for the toilet (straight flush thru) had broken. Ended up blocking the inlet with a cork which fitted from underneath until we got back to the marina and hauled her out. Even a transducer thru the hull could be responsible if it's not sealed well.
As Craney said, water should flow back into the bilge not forward, check all drains and hoses. If there is already a lot of water in the front she may be nose heavy and all water will now drain forward. Start her up and drive her slowly with the nose high and see if the water drains to the rear.
Good luck, hopefully you've already solved the problem by now.
RR
Rick G 01-03-2016 01:40 PM
My flat deck actually has a forward bilge pump located under the step at the cabin entrance . I guess this model did not drain all the way back to the bilge . Rick G.
bajarick 01-15-2016 07:09 PM
Newer boats don't have a drain hole any more from the front to the back. About 8 years ago they made a law to stop it. You have a pump in the cabin some where.
Reason why they stop it fumes got up threw the holes when It was docked and killed a couple people sleeping.
ICDEDPPL 01-15-2016 11:52 PM
^^^^^ We woke up one night and the entire cabin smelled like gas , so bad you could taste it. Leaking fuel tank and the ac sucked it into the cabin. Boat tried to kill us.
New tanks now but them holes from the bilge I sealed up tight.
rak rua 01-15-2016 11:59 PM
I'm assuming the boat is now on the ocean floor and 'way2fast' is still crying too much to revisit the thread....
way2fast 12-22-2023 12:48 AM
I think this is an issue through the sea strainers. Is there any way too stop them leaking
thisistank 12-22-2023 11:22 AM
Dang, nearly 8 years later and still havent worked this out eh?
IGetWet 12-22-2023 11:40 AM
I'd of thought it'd be a submarine by now
way2fast 12-25-2023 05:26 AM
Thought had worked it out and fixed with new plumbing hoses etc but has not solved it unfortunately. Annoying. Especially as don’t really need strainers. Thinking of just bypassing them. And hose directly to engines
scippy 12-25-2023 01:16 PM
You must not use the boat too often to have the same lingering problem almost 8 yrs later......don't eliminate the strainers, but check them under way for a leaking lid etc;
if you isolated the problem to the stainers......there's not much of a problem that can't be easily fixed..........what year is your mistress?i
F-2 Speedy 12-25-2023 01:25 PM
your first post is of water in the V birth area now its the engine compartment
way2fast 12-25-2023 04:53 PM
correct on all fronts. Get a very short season.
im thinking it must be the seals in strainers
way2fast 12-25-2023 04:54 PM
hi speedy. Correct. When there is enough water level that gets in and builds up in engine compartment it files through into the V berth
F-2 Speedy 12-25-2023 05:07 PM
Post a pic of the strainer lid
way2fast 12-25-2023 06:38 PM
https://cimg4.ibsrv.net/gimg/www.off...c21800044.jpeg
F-2 Speedy 12-25-2023 07:11 PM
Ya, might be time for an upgrade
way2fast 12-25-2023 08:51 PM
do you think it’s worth bypassing them and connecting the hoses directly as a temporary solution ??
scippy 12-25-2023 09:41 PM
That's an older mistress...right?
jbraun2828 12-26-2023 08:35 AM
negative, you need to pull the boat and replace the strainers. Also plumb in a ball valve so you can actually clean them out while the boat is in the water
Sydwayz 12-26-2023 08:57 AM
It looks like they still offer the same product:
https://www.jamestowndistributors.co...ct-detail/8166
way2fast 12-26-2023 12:30 PM
yep scippy your exactly right. One of the first 70’s early ones mahogany and teak dash/ cockpit low black windscreen. Etc
