-   -   86 cafe racer 540 hawk (https://www.offshoreonly.com/forums/cigarette/349038-86-cafe-racer-540-hawk.html)
Blackmagic94 08-09-2017 07:21 PM
Rumor is this is one of two boats with the hawk 540 engines and the #3s
what kind of speed should I expect from this hull as equipped.
Where can i find props without converting the hub to #6s
FASTTIMES 08-09-2017 07:39 PM
you buy it ?
https://mohave.craigslist.org/boa/d/...249474950.html
Blackmagic94 08-09-2017 07:47 PM
Looking at it
seafordguy 08-09-2017 08:02 PM
26k. Geez. That really makes me wonder what I'll ever do with mine. Don't want to sink a bunch into it but not worth selling.
good luck with your purchase..,,!!!!!
TracyRR 08-09-2017 09:30 PM
Lot of boat for the money! Good luck on your purchase, looks nice!
thisistank 08-09-2017 09:52 PM
These look like they'd work for 3's.
https://losangeles.craigslist.org/sf...246954625.html
I'm guessing that boat needs some love. just a guess.
frickstyle 08-10-2017 07:46 AM
I would say speeds @ 78mph
F-2 Speedy 08-10-2017 08:31 AM
are those the older #3's or crescent lowers ? cant tell, pretty good deal,
Blackmagic94 08-10-2017 12:29 PM
what is the significance of the difference
Full Force 08-10-2017 08:04 PM
Been trying to get info for almost 2 weeks from this guy....
F-2 Speedy 08-10-2017 08:38 PM
The crescent lower is a newer style and more desirable, and pretty sure it has a larger prop shaft,
TENSION 08-10-2017 08:54 PM
He must run that in shallow water, he's ground the skeg's right off..........
SB 08-10-2017 08:59 PM
https://images.craigslist.org/00y0y_...9_1200x900.jpg
Blackmagic94 08-10-2017 10:57 PM
How much of an issue is the skegs being flush off
Unlimited jd 08-11-2017 10:34 AM
Big
RebarBox 08-11-2017 11:10 AM
I've said it before. I spend 95% of my cafe's value in a restore to recognise a 5% value increase. BUY THEM ALREADY DONE!!
RebarBox 08-11-2017 11:12 AM
81 mph with 750hp at 5400 rpm and #3s.
Blackmagic94 08-11-2017 11:35 AM
Skegs can be tig welded back on correct?
Also can 3a install on a 3 gimble
Bcrawford1 08-11-2017 12:55 PM
Cafe
Speaking of buying one already done who has a café or bullet that's going on the market soon? I have seen everything on FB and listed online currently...
F-2 Speedy 08-11-2017 01:41 PM
sent you a PM, lets take this off this thread
Blackmagic94 08-11-2017 04:54 PM
what pitch and style prop and what is your drive ratio. What kind of slip will good on these 3 blade cleavers
RebarBox 08-11-2017 05:04 PM
3 blade cleavers, 28 pitch, 1 to 1.5. Slip???
Blackmagic94 08-11-2017 05:10 PM
% of prop slip. What rpm did you hit to hit that speed
Blackmagic94 08-11-2017 05:41 PM
15% slip on your run.
My bravo one drive with a 26p labbed cutting edge 4 blade gets 12% at wot and 21-25 at Econ cruise.
I would think labbing yours could cut the slip down and get some faster numbers.
lucky strike 08-11-2017 10:37 PM
Back in the day they would cut them off on the open class race boats to gain some mph.
RebarBox 08-11-2017 10:48 PM
I understand slip. You asked 'What kind of slip will good on these 3 blade cleavers'.... :snide: I do not know what is 'good'?
As stated in previous post - 5400 rpm.
Good Luck!
J-Bonz 08-11-2017 11:26 PM
LS,
Didn't that have something to do with the Michelob Light barrel rolling back in the day..
Jr.
TENSION 08-12-2017 05:58 AM
Yes, I was joking about the shallow water!
There was a engine package offered back in the day, the K-600, that came with the skeg removed. That must have been thrilling to run without some type of rudder.
lucky strike 08-12-2017 10:38 AM
Originally Posted by J-Bonz (Post 4575468)
LS,
Jr.
Good question
