Steering Wheel Fitment (i.e. direct replacement) >
Old 08-22-2017 | 10:31 AM
steve chalupka's Avatar
Default Steering Wheel Fitment (i.e. direct replacement)
Want to replace my current "stock" (cheap looking) steering wheel with a Isotta Carlotta (white) steering wheel on my 2002 Top Gun. Looks like the newer Cigs use this exact wheel. Doubt they manufacture their own. Direct unbolt and bolt on replacement or not? If not, any other direct bolt on replacements?
Thanks.
Steve
From this
To this
steve chalupka is offline
Old 08-22-2017 | 10:38 AM
DiamondPerformance's Avatar
Offshoreonly Advertiser
Depends on your hub, take a picture of your hub without the wheel on it (part where the steering wheel bolts) and I can see what you have. What wheel do you have now?
www.diamondperformanceparts.com
[email protected]
http://www.facebook.com/pages/Diamon...07878772615803
302-521-0123
The Best Parts & Service At The Best Price
DiamondPerformance is offline
Old 08-22-2017 | 10:53 AM
I'll try and paste from Photobucket. I have been having problems with PB lately. Keep asking you to "verify email addresses. Some pics show up & some don not. Isn't that what is happening on the screen shoot? I can only see the Isotta not my stock steering wheel eventhough I cut and pasted it. I'll try again.
Thanks.
Old 08-22-2017 | 10:55 AM
Current steering wheel.
http://i7.photobucket.com/albums/y27...psk5cvczxo.jpg
Old 08-22-2017 | 11:55 AM
Depends on if you are using the current hub or changing it out too. I purchased a 6" billet steering wheel extension from Hardin Marine to bring my wheel closer to me when running so I am not reaching out so far, tried to put it on the other weekend and nothing lines up, allen heads are different size to attach the cap to the hub and my wheel also has 3 phillips head screws to hold it to the existing hub. I hit up Hardin and their solution was to drill out the holes in the wheel and make it fit. Not exactly the answer I was expecting after spending $175 bucks but if that's the only solution I can find to fit my helm/wheel I guess that's it. The wheel I have is a red Livorsi Aria.
HOSSMAN is offline
Old 08-22-2017 | 09:30 PM
pm203's Avatar
Most likely will bolt right up.
pm203 is offline
