-   -   cigarette top gun 38 virgin questions (https://www.offshoreonly.com/forums/cigarette/351467-cigarette-top-gun-38-virgin-questions.html)
F-2 Speedy 12-26-2017 06:32 PM
the tanks should be marked, there is an access lid in the bilge on the step, 100-120 not sure....theres deff something wrong 6k @70 mph is soft.....what trans are in it
ICDEDPPL 12-26-2017 08:15 PM
You adjust the carbs not switch props lol. 1200 is too high idle I think you need someone who knows how to tune carbs. Needs to be closer to 1000rpm neutral and 600-700 in gear.
Lower the idle and add fuel , if they are 4 corner idle adjustment start at 1 1/2 turns out
If really 1000hp and 70mph something is wrong .way wrong.
VortechSS 12-27-2017 09:28 AM
I'm assuming you're the Candyman? 😁
crowfoot 12-27-2017 10:00 PM
The mechanic played with the carbies for ages he said its really odd as the carbies where tuned fine and timings are also good but both engines where performing exactly the same Mechanic is an old school offshore race mechanic and still head mechanic in a offshore team, so pretty confident he knew what he was doing. We had limited time to get it sorted so yes prop change was quickest way to get us thru the through our event. Will revisit the carbies now we have time though, thanks for info.
Also I just checked the gps and it was set to knots not mph.. Stupid me... so we running at 80mph. Sounds better but will try to squeeze some more out of it. Thanks for the replies its appreciated.
F-2 Speedy 12-28-2017 06:28 AM
That sounds more like it, good luck
rak rua 12-28-2017 06:33 AM
Don't hold back, 70 knots is 84 mph. (Every mph counts) :)
RR
Jim Diesel 12-28-2017 09:32 AM
Congrats, Nice boat and power!!
I had also seen the video of the boat being wrapped, how well will the vinyl hold up on the bottom of the hull? I wrapped my previous boat and had some issues with the vinyl peeling around the corners at the transom, just curious how wrapping the bottom would hold up.
bigfarmer 12-28-2017 09:33 AM
Originally Posted by crowfoot (Post 4601267)
Hi all
My boss just got a great condition 1999 Top Gun 38 with BDS super charger, I believe they are 596cc blocks with 3A drives, engine pic and others here http://www.dropbox.com/home/boat?pre...6_1_XLARGE.jpg
It came with 4 blade cleaver props that where 33's we had trouble at low speed with the engines stalling as soon as put in gear. the boat was used on an event that had to be used at slow speed so our mechanic swapped the props to 5 blade 31's Herings to help the stalling a little. we still have to trim up close to out of the water and give it a bit of throttle to get it going. So my question is is this normal to stall at idle with no throttle? Our mechanic played with the carbies and cleaned them said they where ok. The boat was a freshwater boat originally and we are in salt water.
We are seeing a top speed of 70mph at around 6000rpm with the 31 Herings. I would have thought it would be quicker than than that. Comments.
Crowfoot.
Something is deff wrong, i could run that boat up to 94mph everyday on 93 octane gas, What did you set the timing at? I was able to reach 97 mph the odd time in the right conditions. Those Trans have maybe 10 hours on them,1200 rpm is too high at an idle and you will eventually hurt the trans if shifting at that speed. Stalling was an issue at times when shifting with those engines, bumping the throttles during shifting helps. The engines are 589ci intercooled that Frank Mccomas from Scorpion Racing built which made over 1000hp on the dyno, not sure why you have to "trim them up to get it going"? tuck the drives in all the way and lower the tabs and give er it will get on plane no problem.....your most efficient speeds will be with the drives and tabs set on those little silver marks i put on the indicators. I could cruise at 70+mph around 4500 rpm.
bigfarmer 12-28-2017 09:40 AM
Originally Posted by crowfoot (Post 4601405)
it drank over 200 gallons when it was filled but we have no idea what was in it previously as gauges and sender's might need replacing. that 70mph was done on full tanks with 3 passengers. it's has full cabin and we running 98ron gas.
Use the Flo Scans on the dash on the port side above the map holder. The boat holds 220 gallons, fill it up to full and reset the gauges using the little white switches underneath them. This will count how many gallons have been burnt. just have to subtract what was burnt compared to how much you put in.
bigfarmer 12-28-2017 09:54 AM
If you REALLY want to get her moving i have Everything needed to convert it to a #5 boat on boxes, it will run right around 100mph but is a bit harder to get on plane...
