-   -   Top Gun Hatch Seals (https://www.offshoreonly.com/forums/cigarette/352525-top-gun-hatch-seals.html)
HOSSMAN 02-27-2018 09:14 AM
Top Gun Hatch Seals
I apologize if it has been posted before. I was working on the boat this past weekend and when in the cabin I noticed daylight in some areas between the hatch and deck. Any idea on where to get new hatch seals or if some of you have made your own what did you use? I assume the 35 Top Gun hatches are the same as the 38's. Thank you in advance.
MAXIMUSXXX 02-27-2018 09:27 AM
I think it's the small gap where the two ends of the seal strip meets. Put some clear gasket sealer on it. Let it set up and close hatch. I think I did on the boat once. Also, Lipship sells them.
BDiggity 02-27-2018 11:10 AM
I think you can get D seals pretty much any hardware type store. There are even different options like ribbed (for her pleasure) seals. I changed mine over to the ribbed.
cigrocket 02-27-2018 12:43 PM
Simple, here is the distributor
www.mcmaster.com
Done
VortechSS 02-27-2018 01:11 PM
When you measure yours, please post the dims of the factory D-seal. I'd like to order some from McM as well.
HOSSMAN 02-27-2018 05:09 PM
Thanks for the replys and link all. Apprecite it and will let you know.
1MOSES1 02-27-2018 10:16 PM
we just re-did ours...it’s 8’ across and 5-6’ down each side. I’d buy 20’. It’s cheap enough.
1MOSES1 02-27-2018 10:18 PM
HOSSMAN 02-28-2018 12:06 PM
Thanks for the reply. I will check my engine hatch seals too. Sorry, I was talking about the deck hatches of the cabin.
Jim Diesel 02-28-2018 06:37 PM
1MOSES1 02-28-2018 08:58 PM
I missed the whole deck hatch part...
One thing i will say about the engine hatch, we didn’t use the 1/2” d-moulding. We used the 1”. It came out better.
HOSSMAN 03-01-2018 07:00 AM
Originally Posted by Jim Diesel (Post 4613189)
Thanks a million Jim! Appreciate you doing that for me. The boat is an hour from us so you just saved me a ton of time. You doing Tickfaw this year? If so see ya there!
Jim Diesel 03-01-2018 11:13 AM
No Problem, thats the same size for the cabin door as well! We had planned on it but a few things have changed so not this year, we are doing Cig Rendezvous, Old Hickory, and a local run here on KY and Barkley Lake. The maybe list is Lake Cumberland or a long shot of Emerald Coast.
