Cafe help
Question one. My cabin hatch is off the upper track rail. How can I get it realigned 2 where is the factory inverter charger located or the wiring in the engine bay |
If like the Gun, charger should be mounted to the bulkhead facing the front of the engines. May want to check the output, I had one die on me. It would turn on like it was working, but nothing coming out of it to charge the batteries. got stuck after an overnight one time because of it.
I’m not seeing any electrical boxes that would look like a charger. Just 5 trim pumps and relays. There is is a wire that had a buss fuse and the fuse is gone and the wire is clipped on the far port side on the firewall by the trim pump |
Originally Posted by Blackmagic94
(Post 4634101)
I’m not seeing any electrical boxes that would look like a charger. Just 5 trim pumps and relays. There is is a wire that had a buss fuse and the fuse is gone and the wire is clipped on the far port side on the firewall by the trim pump On my Cafe, four (drive & tabs) are on the starboard side. my trim pump is mounted under the rear bench port side. The charger/inverter, i believe was a Charles brand, mounted near the fire extinguisher on the port side. |
My hatch pump is on the same wall |
| All times are GMT -5. The time now is 11:56 PM. |
