-   -   Dock roof height for 35' or 38' Cig.?? (https://www.offshoreonly.com/forums/cigarette/356687-dock-roof-height-35-38-cig.html)
jwforbes 09-15-2018 01:46 PM
[Question]
What is the height needed for a 35' or 38' TG to clear the roof, while on a lift? I'm looking for two measurements. First being highest point (wind screen?) to surface of water and second from deck (top near bow) to surface of water.
[Overview]
I plan to purchase a 35' or 38' Cigarette. However, I need to modify a dock slip. I'm considering my 10' x 32' slip, install a 12,000 lb, 6-arm, back-in (DD) PolyLift. With this setup, the bow will extend out of the slip a few feet, and be underneath the entry point/roof.
Here at LOTO, the dock & lift receive water action, so I would like to ensure I have enough clearance.
Thanks!
Jamie
Griff 09-16-2018 12:34 AM
There are dozens of Cigs at LOTO on Polylifts. Best to just go measure yourself.
omerta one 09-17-2018 02:13 PM
Originally Posted by jwforbes (Post 4649310)
[Question]
[Overview]
Thanks!
Jamie
The standard height for a slip is equal to the width: 10 wide x 10 high; My 39 was about 6 feet tall (above the dock) to the windscreen on a poly lift.
Knot 4 Me 09-17-2018 02:20 PM
Height shouldn't be a problem but a 38 TG with a swim platform will be sticking way the heck out from underneath a 32' slip. Might have to install a blue light on the nose!
jwforbes 10-10-2018 10:42 PM
Ha!, yeah.....I'm installing a back-in lift, so to protect mainly from rain collection.
jwforbes 10-10-2018 10:47 PM
Thank you for the measurements. With this information, there should be plenty of room for lift vs. dock movement. I may also install 'stop tabs' on the lift arm(s) to limit the upward movement as to prevent any possibility of the boat's deck from hitting the dock's roof at the entry point to the slip.
Again, thanks everyone for the feedback.
Holy Smokes 10-11-2018 10:10 AM
I'd be sure to double-check with the lift guys and the dock guys. 38' Cig in a 10x32 slip will be tight width-wise and likely 10'+ sticking out the end. Also, the lift eats up some of the width. My 17k galva back-over in a 12' slip has only about 9'8" between the pitman arms.
Knot 4 Me 10-11-2018 11:02 AM
Yeah depending where your dock is located the Ameren/Water Patrol may have an issue with that much boat sticking out. That is why I joked about the blue light on the bow. At night what would be lit up as the end of the dock would not properly indicate how much hard surface you have to avoid.
From the Ameren site. Might save you some headaches down the road.
The maximum boat slip size shall not exceed 55 feet in length for residential permits and 60 feet for commercial (marina) permits. Any watercraft moored within slips permitted after March 30, 2008 shall not extend beyond the mouth of the slip.
https://www.ameren.com/missouri/lake...k-requirements
apex svt 10-11-2018 07:05 PM
OP, call poly lift. I see that green and red 38 top gun with “poly lift” on the front running around all the time. They will have the measurements.
As for the slip length limit, what do they do with the 55ft+ cruisers that I’ve seen out there? Slip can’t be bigger than 55ft and it can’t stick out, yet boats larger are out there.
Knot 4 Me 10-12-2018 07:47 AM
I'm just saying sticking that much boat in that little slip might open you up to some issues down the road whether it be neighbors hassling you to possible litigation if someone takes their head off on the bow in the middle of the night. I'd think twice about it.
