94 Top Gun Cabin Door
Never had this issue before. Took the boat out today...cabin door opened and closed without an issue. Did some ocean running and now when we close the door...or try to close the door it only goes 1/2 closed and then stops. Not sure what it’s hitting. Anyone ever have this issue? What’s the easiest way to figure out what it is...don’t feel like taking the whole dash apart. Thanks. |
Originally Posted by 1MOSES1
(Post 4696643)
check the track as well, sometimes they wear through or it jumps it. also the wheels in the door will wear out sometimes. I think phil stocks them.
Originally Posted by VortechSS
(Post 4696645)
With the door partially open, you can look in between the face of the door and back of dash with a light and see if there is something stopping the door from sliding in. That would be where I'd start.
(Post 4696654)
(Post 4696643)
(Post 4696672)
doesnt feel like a wheel or track issue. feels like it’s physically hitting something. When I did peak there are two pads sticking out from the gunnel wall that act as supports. Wondering if one shifted and is now hitting.
also make sure a screw hasnt backed out of the track or the bulkhead
Originally Posted by Jim Diesel
(Post 4696690)
If your trying to close the door and its going halfway, wouldn't the issue be from port going starboard in front of the door and not behind it? Here is a pic of the stops your talking about, this is when I had mine apart and the two red lines represent the track.https://cimg8.ibsrv.net/gimg/www.off...0847038c3e.jpg
Think I confused everyone including myself...the issue is in the opening direction. Not closing. My bad. When I try to open it goes 3/4 open. I can squeeze into the cabin but not by much. So the door is coming close to those stops. The screw suggestion is a good one. How much of a PIA is it to take the dash out to fix?! lol |
(Post 4696713)
Working on these old guns is a nightmare. Absolutely no consideration to anything having to come apart after the fact. Can anyone comment does does the co pilot chair and surrounding vinyl pads have to come out in order to pull the dash. I got all the screws off but the dash won’t budge. Thanks |
Screw backed out of the track. https://cimg4.ibsrv.net/gimg/www.off...91baf97eb.jpegFun times!!! |
That doesnt look like fun...... |
Got it all back together last weekend. Ended up putting 4200 on the screws to prevent future issues. Hopefully I don’t have an issue with the track itself lol |
Annnnd, back to boating...... |
Wow!! That's a pain in the a-s-s!! All that for one screw?!
Glad you got it figured out! |
Originally Posted by TomZ
(Post 4699673)
Glad you got it figured out! co-pilot chair top vinyl pad lower vinyl pad front vinyl pad gps grab handle interior pads to gain access to handle gps antenna kick plate front dash these things are built like jig saw puzzles. Half the boat has to come apart. |
| All times are GMT -5. The time now is 11:20 PM. |
