(Post 4733348)
I just measured its 4.375 to 4.5 from the bottom of the hull to the center line of the bullet....
Originally Posted by IGetWet
(Post 4733328)
Now that F2 mentioned that I looked at that as well, hard to tell depth but looks like a pretty good size notch in that boat! I haven’t looked at a ton of 39s but I don’t recall seeing that big of a notch in others. That would obviously play a big part in drive height.
Originally Posted by endeavour32
(Post 4733352)
Is yours a 38 or 39. A 38 will be set up deeper than a 39.
PBC had the purple 39 center steer for sale 7 or 8 years ago, it had 525’s, I was looking it over pretty good, I do recall the drives being very high, probably only an inch or so below the bottom, I would imagine yours would be in the same neighborhood
(Post 4733348)
(Post 4733348)
(Post 4733392)
i meant the op's boat has its, so he has plenty.
(Post 4733359)
38....but this is an X race boat and Id heard they were set up a little higher than norm...
Originally Posted by JaayTeee
(Post 4733360)
I would measure mine for you but the drives are not on the boat. I would definitely run big props on your boat if possible. The difference between them and bravo props is night and day, especially on Lake Michigan. Mine also sucks to get up on plane even with big props, I have 17/35 herrings
| All times are GMT -5. The time now is 01:15 AM. |
