-   -   Topgun non step props? (https://www.offshoreonly.com/forums/cigarette/367863-topgun-non-step-props.html)
division1 08-07-2020 09:16 AM
I have a 1990 straight bottom had stock 575 sci and Konrad 540s boat spun 30p 4 blade to 5200 for best of 79.6 and 28 5 blades at 5150 got 80.8 so something seems off with engines unless drives are super deep
division1 08-07-2020 09:24 AM
If your having trouble spinning a 4 blade 28 more than 5k a five blade 28 won’t be the answer it will help your cruise but not top you need more rpm try a 5 blade 26p b1 prop that should get you decent cruise and a bit more top
F-2 Speedy 08-07-2020 09:36 AM
where are the drives trimmed to when trying to get max speed, are you trimming them out as the boat comes on plane
division1 08-07-2020 12:05 PM
Also something to think about is xrs on a straight bottom and bigger power might wasn’t to stay with a 4 blade I may have some 26p 4 blade off my old bullet you can try
EC2007 08-07-2020 12:18 PM
mostly cruise anyway, top speed just for grins now and then. I am thinking 26 might be the answer.
EC2007 08-07-2020 12:19 PM
sure let me know !
EC2007 08-07-2020 12:21 PM
last time I went for top speed had the drives at “4” on the indicator
going to mark my indicators at neutral and above neutral for reference.
division1 08-07-2020 05:34 PM
I’ll look this weekend when I’m at the shop working on the old girl
EC2007 08-07-2020 07:12 PM
Originally Posted by b18cls1 (Post 4751853)
they will be for sale in about 3 weeks.
probably a conversation for other thread but quickly what’s the difference between hydros and bravos for these heavy flat bottoms?
division1 08-07-2020 07:42 PM
A standard flat bottom seems to really like 4 blade b1 props my boat has been re rigged with a higher x so it likes 5 blade props a lot I haven’t had much luck with hydros on the cigs but seems some people do.
