Bullet?
Anyone familiar with the 1990 bullet in Connecticut listed for 35k ? 454's/Bravos, white wrap and black upholstery and sun pad. Been there awhile
Don’t know that one, but if you’re looking for a little bit of a project I have one for sale. Was going to part it out just haven’t had the time.
Was that the one you had up for parts last fall?
. My plan was to start with a hull and build something over a few winters. I take the winters off and usually do a classic car or a bike but I'm getting the itch to do a boat. I am starting to think I should start with a project that's all there first before trying to piece something from scratch. I like that bullet in Connecticut but after seeing posts about wood cores etc. I dont want to bite off more than I want to chew. . How much of your bullet has been sold off? |
Originally Posted by PC119
(Post 4822115)
(Post 4822133)
It's on boatscom or powerboatlisting in old saybrook.
. I have read through literally hundreds maybe thousands of posts from different threads trying to get a bit more educated on what I would be getting into. From transoms and stringers to outdrives to the floor decks etc. I think for sure when I figure something out I'll be coming here to ask some questions. I still have a load of threads to dig through. . Looks like I should find something I plan on liking and holding on to because after buying it and going through any type of restoration she will be worth less than I have into it but I still want one. . |
If you can get lucky and find one that Dustin Carter built- you will be Way ahead in the long run. May cost more in the beginning but i bet you will save in the long run.
Yep, that one
$35K with trailer buy it not sure on performance but cool boat! Even if you put more $$ still worth it instead of going out in the jungle to purchase the boat you like! (Buyer beware) Good luck PS run it as is if possible when you buy it ?
I sent an email not long ago for some more pictures and no reply.
. If I get to a point where I need a surveyor would oso be a good place to ask for one? or get recommendations on where to find someone experienced with these boats? . Winter seems like a bad time in the northeast to search for something the more I get into it. Frozen moisture for bad readings and probably no test ride should pause it for me I think. . |
Thanks for the feedback, it looks like someone sent a message but I cant access the inbox so just letting whoever it is I'm not ignoring it
If you are still interested in a bullet, I have one with 100 hrs on a new transom, 502s, and teak swim platform I am thinking about selling.
avalaunch I'd be interested in learning more about your Bullet if you move forward with selling it.
Originally Posted by Unlimited jd
(Post 4822130)
| All times are GMT -5. The time now is 03:00 AM. |
